Bit of a choice you've got there vtss5spd...
COME base there HP/KW power at the flywheel, so allowing for drivetrain losses you are probably going to need around 270kw to make 200kw at the rears, add to that an exhaust to match and a clutch (if not a new gearbox,ie 6speed) to handle the power and it can get pretty expensive....
Forced induction technology has come a long way and with engine management, boost is now very freindly to the enviroment (EPA)
and there are a few kits around that can be ADR Certified. Capa do a few of these and a place over here in West Oz,
http://www.marksworkshop.com.au/Pages/mws.htm ,does an excellent Eaton kit. I have a stage 2 Eaton kit on me ute and with 350hp (260kw) at the rears it is pretty good bang for buck on a totally stock 5litre. It's well mannered and me missus drives it all the time. The stroker in me GTS is the other end of the spectrum with a worked 355 stroker complete with lumpy idle and heavy clutch and box, it pigroots at low speed and is not very missus friendly
Have you thought about rebuilding your 5 litre with boost friendly internals (Forgies, H Beams, ARP Stud/Bolt kit,etc) and then running either NOS, Turbo's or Supercharger down the track when you've saved a bit more cash...
Anyway, interested to hear your thoughts and here's a couple of links to some info on extrude honing the 'ol bunch of banana's, apparently only costs around 800 bucks to do yours and mated with Perfectune's (Yella Terra) new 71mm throttlebody would probably yield some good results....
http://www.aussiev8.com.au/showthread.php?t=1360&highlight=abrasive
http://www.abrasiveflow.com/first.htm
