GK813
- Nov 25, 2017
- 140
- 17
- 18
- Age
- 45
- Location
- Victoria
- VS Berlina
My VS Ute is lowered and it had 17 inch rims that made it fell every bump on the road so I put stock 15 inch rims on for more tyre between the road and the car and its a lot better but if I was to change the lowered springs and shocks/struts to stock non lowered would I notice a big difference? I dont know what type of springs are in it now if you want a picture with the wheels off let me know but I have a side pic of the Ute below. I also have a VS sedan with stock springs is the sedan and Ute parts swappable or do I have to buy some sort of kit? I noticed on the Ute when I was changing the bump stops that on the rear drivers side the 17 inch wheel that was on it before must of been scraping on the inside well behind where the wheel sits I was reading that if you lower a Ute it needs a bar of some sort to adjust the diff from moving from being lowered I'll take a pic later but what is the bar and where is it located, the guy I bought it from might not have installed it. One last question about springs is would you recommend stock or is there a higher/longer spring to raise it up more.
