Wreck help
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
vs v8 the ecu is the same as a vr v6/v8 ecu not the same as a vs v6 one
maginoodle
vy series2 ss crewman
Hi delco, so if i use an ecu from a vr(i have one) and put the memcal(that is the removeable chip in the ecu isnt it?)i should be right to go.
Because i didnt have the key for the original barrel i changed the complete barrel, so now i have the key and remote that match the bcm i put in.
It still didnt have injector pulse. So i had another look and realized i didnt put the earth wire back on the ign housing. It now has injector pulse but it only runs for about 10-20 seconds and wont rev. Is that because the ecu and the bcm isnt linked?
Cheers Shane
Brett_jjj
Tamworth NSW
vs commodore
The VS doesnt need the BCM matched or linked to the ECU with a Tech1 or Tech 2 scantool.Only the VT and later models use this setup.Not the VS or earlier.With the VS,as long as the ignition keyhead matches the BCM,it will start.
maginoodle
Lesson 1 for today- check the simple things.
Came home today and decided to kick it over, went first go and didnt stall. Tried to work out what i have done and the only thing i can think off is pushing it out of my shed. The rear entrance to my shed is downhill, so i am thinking lack off petrol in the tank.
Thanks everyone for the help.
Cheers Shane
