wtf have i done..... help
glennis
brisvegas
vr acclaim wagon, vs wagon (project) & vx belina
yeah it is a hose connects to this spout and runs to the heater tap..
Brett_jjj
Tamworth NSW
vs commodore
Looks like yours was corroded and snapped off where the pipe joins.
glennis
brisvegas
thanks for that Brett_jjj , thats just what i need....... where do i find the part number for the inlet pipe
Cheap6
VP Exec
Any parts store that sells it will be able to find it without the part number. I suspect that it may be genuine only but sometimes I get suprised by what the chain franchises sell.
I would be trying the wrecker option myself => <<<$$ but it depends on how easy that option is for you; if you are out in the sticks somewhere... You should still be able to find a good one without very much corrosion on the sealing surfaces.
You do need the correct size 'O' ring also.
glennis
brisvegas
yeah plenty at the wreckers, so i think ill just get a new one prob will come with the required o ring
Brett_jjj
Tamworth NSW
vs commodore
Im not sure if or where you can find it online.Any car parts place like supercheap or even holden will be able to tell you the part number straight away.Just give em a call.Im pretty sure all the ecotec engines use the same heater inlet pipe..
glennis
brisvegas
yeah thansk.... do u know much about lsd diffs, i have one t-ed up to pick up tomoorw, says its a lsd how do i confirm this, both wheels spin same way or oposite
Brett_jjj
Tamworth NSW
vs commodore
The same way.
glennis
brisvegas
cool thanks
