Xenon Light Globes
Haze
melbourne, victoria
VS Commodore
are xenon light globes any good for a vs commodore?
kopper69
VRII Acclaim
Mate head down to autobarn and check out the globes they got there. I dont know what your after, whether you want brighter or whiter, but they have both types. You can go as bright and/or as white as you want but there are laws affecting the brigtness of the globes. Dont go too bright or they will look like a dentist lights and cops will notice and will book you. Saying that, the prices do vary too - up to $110ish for a set. And remember not to touch the bulbs with your fingers or they will leave hot spots which cause the bulb to fail faster. I dont know why you specify xenon - does it really matter what gas the bulb is filled with?
HIROLLA
vic
VS SIII CAPRICE
Im looking at buying a set for my headlights does anyone know what type of connectioned bulb i need to buy to work with the vs stato headligths? Im looking at also replacing the parkers with some coloured ones.
Any help would be great
_Mukas_
DJ Titan...Hardstyle guru
Edithvale born n bred...
VR 5.0L Statesman
actual headlights youll need a h4 type. xenon are the blue/white quartz headlights that cut through the fog and makes night driving a lot better, makes the lit up areas look like daylight, not artificial yellow... i have 90w ones, cost me $35 from supercheap, in my commo and they look awesome, everyone comments on them, which i spose is a good thing :) 90w are illegal though ive been told, may not be, but i keep my original lights in my glovey if the po-po get narky just in case...havent had a problem as yet and have had them since late feb.
WiLo
Wollongong
VS exec
flipsyde said:
i got 100w and der good no problems must be a hassle for other drivers tho. i dont like it when i see a car aproachin me with them installed.. too bright
you dont like it so you installed them in your own car? that sounds really logical
bradvt98
tasmania
1998 vt executive
i brought phillips crystal visions from autobarn yesterday they look sweet set me back $99 still have to get the high beam ones still
Shounak
The Kicking Horse
37
VX Executive S2 + XF Panel Van Project
Were they H4 or H1.. Because I was sure this is the normal one..
HIROLLA
vic
VS SIII CAPRICE
so the H4 would work with my stato headlights? Just plug in cause i know theres different connections
RedLiner
37
VR Series 2 Commodore
Yes I believe a statesman has a H4 globe also. Just pull the old globe out and have a look.
