AaronW
For the early models (VB-VP) the strut/hub are a single unit and needs to be modified to suit a coil over set up rather then the more simple bolt-in option of the later model Commodores.
You will need to remove the strut and strip it (remove the strut top mount which will release the spring. Then you can remove the shock absorber insert).
Once the strut is fully dis-assembled you will need to have the factory spring mount removed (ground off) and then the new threaded body for the coil over assembly will need to be welded onto the strut. Seeing as you are asking about this I would recommend that you have this done professionally. The kit supplier should be able to recommend someone to do this for you. Once the new threaded body is welded on you can assemble the new shock absorber insert into the strut, then fit the spring and the strut top mount.
If you go and have a look on the AV8 forum the user Smitty2 put some pictures up of the latest set of coil overs he fitted on his VK race car. I believe Smitty is a user on this forum also but I don't know if he frequents here very often.
Thanks for the info mate
