ok I'm going to have to spell it out
VSS refers to the application of ADR's to vehicles
ADR 18 - stipulates that a vehicle must be fitted with a speedometer, which complies with the conditions of ADR18, including a tolerance of +/- 10%
Unless otherwise 'Approved', every vehicle shall be fitted with a
speedometer which shall
indicate the actual vehicle speed, for all speeds above 40 km/h, to an
accuracy of ± 10 percent
A vehicle built to comply with ADR18 must have a complying speedometer.
Section 20 of the road rules A driver must not drive at a speed over the speed limit
lets break that down to one of the significant elements of the offence - drive at a SPEED.
By what means is a vehicles road speed determined ?
There is no definition of 'speed' in the Road Rules Act dictionary. So lets go back to the TORUM Act - no definition of speed.
Macquarie Dictionary is the next approved definition. I haven't got access to that in my motel room tonight. But I doubt it is going to stipulate that a police speed detection device is the only means of measuring speed. A vehicle built in compliance with ADR rules includes a mandatory ADR compliant speedometer. ADR is part of common law. Which means an ADR compliant speedometer, fitted and operating in accordance to ADR specification is a legally accepted road speed measuring device - ADR stipulated tolerances included
Ok, might be easier putting it in a court room scenario
Let's say the speeding offence actually made it to court
Prosecutions states - 'your road speed was assessed at 105kph in a 100kph zone'
Defence states 'my client states his speedo indicated 100kph'
Prosecutions states - 'that might be, however the police officers speed detection device assessed your client's speed at 105kph'
Defence states - 'this is a 2000 model vehicle, fitted with the OEM speedometer, which complies with ADR18. This device is the only device provided by the manufacturer for determining road speed. ADR18 allows a +/-10% speed tolerance for this device. My client has stated that the speedometer was reading 100kph at the time of the alleged offence, so to the best of his knowledge he was travelling within the posted speed limit. According to the police officers speed detection report, he was indeed travelling at a speed that was within the acceptable tolerances as stated in ADR18 for that speedometer. Could you please suggest to the court what other means you would expect my client to have reasonably used, in determining his road speed apart from the manufacturers complying speedometer ?'
In fact, I suspect police would already take this into account when they consider issuing a speeding infringement. If the vehicle is pre- 07/06 they probably won't issue an infringement for less than 10% over.
End of the day take or leave it. You can choose to just roll over and accept a speeding ticket for a few kays over when driving a pre 07/06 vehicle, when your speedo indicated that you were travelling at or under the posted speed limit. Or for little to no cost, you can write a letter to the prosecutor stating your case and have a very good chance of the infringement being waived....
