IQ System New Software fixes 21 IQ Issues.
RiCeY
F O R U M W A R R I O R
Australia
VZ SV8 6spd 6.0 430rwhp
Issues fixed by new software release.
1. No display (black screen), no sound and no function (only hazard light button functional).
x Condition is typically recovered by cycling the ignition.
2. CD plays slow intermittently. Only affects base level vehicles without “Stored CD” function.
3. CD forgets position.
x CD starts playing from different track to the previous key cycle.
4. HVAC button stuck.
x Button behaves as if it is pressed continually.
x Most commonly seen in fan up/down buttons.
5. Reverse Camera stuck on.
x Reverse camera display may remain on the screen when the vehicle is placed in drive.
x Screen can be black when vehicle in drive.
x Screen can be black with reverse overlay (coloured lines) when vehicle in drive.
6. Reverse camera doesn’t show when vehicle placed in reverse.
x Radio behaves as though reverse was not selected.
7. Internal component communication issue may cause one or more of the following symptoms:
x Navigation does not load (no popup).
x Navigation starts to load (loading popup appears) then popup disappears and Navigation does not
load.
x When on/off button pressed to turn radio on/off, radio screen remains on screen although audio does
turn on/off.
x HVAC status not displayed on status bar.
x Clock not displayed on status bar.
x Calendar screen (displayed when radio turned off) does not show any text, only background graphic.
x Remote (steering wheel) controls have no apparent effect on the radio.
x "Set time" option on config menu shows incorrect numbers, e.g. Hour = 87, Minute = 99.
x "Set date" option on config menu shows incorrect numbers, e.g. Date = 99, Month = 99, Year = 9999.
x HVAC controls inoperative.
8. Radio doesn’t shut down.
x Radio is observed to be on (clock screen) after more than 60 mins since key off.
9. “CD too hot” displayed on HIQ Screen.
x With or without CD in unit.
10. Rear speakers not muted in headphone mode.
11. Volume escalates without user input.
x Volume control inoperative until ignition turned off.
12. CD Track title incorrect.
x Song being played does not match the song displayed in track information bar.
13. iPod track titles missing.
x iPod track name information and progress bar not displayed after an outgoing Bluetooth call.
14. “Reading iPod” popup stuck on screen.
x With iPod/iPhone connected.
15. HVAC temperature set point display shows “C”.
x Radio displays “C” when the HVAC temperature provided is different.
16. Screen brightness cannot be adjusted, radio configuration display shows “X”.
17. No Sound Following Crank.
x All sources affected.
x Recovered by an ignition cycle.
18. Black Screen and no keyboard backlighting.
19. Radio Resets.
x IQ system goes blank then system restarts.
x Does not include the system reset when a low voltage crank occurs.
20. iPhone audio not paused during a Bluetooth call.
21. Virtual CD (Stored CD) current track asterisk not updated.
Revised HIQ Software was applied in production from.
ISOVIN: Built Date: 6G1******CL628884 23/01/12
RiCeY
Australia
Vehicles beyond this VIN 6G1******CL628884 and built after this date 23/01/12 already have the new software.
Troyziee
MY17 SSV-R Sportwagon
so whats the go with this, is this another system update for ALL IQ system owners or only those built after that date?
RiCeY
Australia
Reaper
Tells it like it is.
RG Z71 Colorado, 120 Prado , VDJ200, Vantage
And will Holden send out a bulletin to existing owners to update their own like they did last time???
Reaper
RiCeY
Australia
No it isnt a campaign so the new software will be installed apon complaints that relate to the list above.
If you have any of these issues you need to book in for an update.
vicarious
47
SA
VE2 SV6 SPORTWAGON
no name of person comes up when they call?
Reaper
Anybody know if the IQ software update will affect a ecu tune?? I presume not but would like to know for sure???
Reaper
RiCeY
Australia
Reaper
IQ unrelated to ECU so you wont have any issues there.
vicarious
47
SA
VE2 SV6 SPORTWAGON
how long does an update take?
