Y
YoungOne
Guest
hey guys, just wondering what your opinions are on this. i have a 98 VT Exec with almost 250 000k on the clock. my plan is to see if she will make 300k then re-co the engine, after that is done, supercharge it, similar to what PowerUp did - http://forums.justcommodores.com.au/showthread.php?t=8921 with the overdriven S14 supercharger CRS kit for around $2500.
-OR-
Get a new factory supercharged 3.8 and get that put in, because i hear they go for around $3500, the reason for this is, the s14 charger kit would be around $2500, on top of that there is the cost of rebuilding the engine, which i am unsure of the price for.
Now, what i was thinking, would the factory s/c engine, running 6-7psi, put out as much at the wheels as the s14 s/c running a constant 8-9 psi? Or would it need to be modified? If it does how much power could i pump out of the factory s/c? i dont want to go to the extent of toughening up my gearbox and diff, but if i have to i have to. Also, getting the new engine, would i have to upgrade to ecu and all the other gear?
Just one last little thing, it probably sounds really dumb, but your see and hear about twin turbo engines, has anyone ever seen or thought about a twin s/c set up?? just curious...
sorry if all this doesnt make sense, im really tired...
Thanks for your thoughts.
-OR-
