+ Reply to Thread
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 26 to 50 of 71
Thread: DIY: ECU Scantools/Data Cables
  1. #26
    michaelw's Avatar
    michaelw is offline Donating Member michaelw Berlina
    VX S2
    May 2005
    Newcastle NSW
    Try this. send AT SP0 to the cable through hyperterminal or your scan software. This will tell it to try ALL protocols when it has trouble. The chip has a 'feature' to remember the last protocol it used and if you are swapping it around it could get annoying.
    For more info check page 11 of the data sheet.
    http://www.elmelectronics.com/DSheets/ELM327DS.pdf
    Mike
  2. #27
    Chev_SS Guest
    Does anyone know where i can purchase an interface cable for a series II VY commodore SS.
    I have downloaded the trial version of EFILIVE but i need the cable.
    Thanks
  3. #28
    michaelw's Avatar
    VX S2
    May 2005
    Newcastle NSW
    I have made an addition for those who have a GENIII and can program microcontrollers.
    Mike
  4. #29
    michaelw's Avatar
    VX S2
    May 2005
    Newcastle NSW
  5. #30
    VS V6 T5 & VY V6 M35 UTE
    Oct 2004
    Jurien Bay WA
    Quote Originally Posted by michaelw
    News just in. EFILIVE has definition files for VX and VY V6's
    Mike
    This sounds like good news, but can you tell us what It means for us now ?
    Deek
    Aussie Aussie Aussie, Oi Oi Oi .
  6. #31
    Apr 2006
    Hi Guys,
    Can anyone provide a copy of the standard bin files/maps for the VS ECOTEC amnual as Im conveting to manual form auto. Please PM me if you can help
  7. #32
    michaelw's Avatar
    VX S2
    May 2005
    Newcastle NSW
    Quote Originally Posted by OZ38
    Deek
    You can see what efilive can do before you make/buy a cable, dowload efilive (the version on the server comes with the VX/VY V6 files) and after it is set you go to file->select vechicle and load the file. Some VX's may have a problem with the supplied file (see attached for a corrected file).
    Mike
  8. #33
    VX II
    Jan 2006
    Default Here it is....
    Ok I have done the work for you Here is all the info you need to make your very own ALDL link. I have done it, and it works on my VX II commodore.
    Attatched are the schematic, part layout, and PDF for making a PCB for your link.
    There are three options for powering this circuit
    Option 1 on the car side use Ground Data and 12v // on the PC side use pins 2, 3, and 5
    Option 2 ointhe car side use ground and Data/// use a 9V battery on the power in pins /// use pins 2,3,and 5 on the PC side.
    Here is a link to download an ALDL tester to test youe citcuit BEFORE you hook it up to your car!!!
    http://www.ttspowersystems.com/softw...setup-ALDL.exe
    Here is a link to the circuit that I used.. It seems to be the best.
    http://students.fct.unl.pt/users/lat...link_cable.htm
    Note you have to conect pins 1,4,6 and 7,8 at the serial port plug.
    Here is a link to the serial plug pinout:
    http://www.cisco.com/univercd/cc/td/...1101/cable.htm
    You have a DB 9 on the back of you PC.
    I used EFIlive 4:
    http://68.178.219.18/software/EFILiveV465_305_Eval.exe
    Have fun
    Mike
    aldlfinal3.zip
    aldlfinal3_brd.pdf
    DIY: ECU Scantools/Data Cables-aldl_interface.gif
    DIY: ECU Scantools/Data Cables-aldl.gif
  9. #34
    michaelw's Avatar
    VX S2
    May 2005
    Newcastle NSW
    Quote Originally Posted by Mike:)
    If you join the DTR and RTS lines together to power your circuit you run the risk of cooking your serial port. Route the power through a diode for each line. (see circuit on first post).
    If you want to power it off the car (no real need unless you have a cheap laptop, cheap usb/serial converter or want to use a pda) you can source 12V from pin 16 on the obd plug. No need for a 9V batery, the battery/cig lighter power option is needed on US cars that have a different OBD I plug.
    Mike
  10. #35
    VX II
    Jan 2006
    Hi there,
    Yes there are diodes to protect DTR and RTS. I am using the same basic circuit as you.
    Just have a few power options. - it works from a pda which is cool!
    There is a PDF to make a pcb from. Thought it might help a few people.
    Mike
  11. #36
    michaelw's Avatar
    VX S2
    May 2005
    Newcastle NSW
    Added some info about the airbag flashing when you use an adaptor on the VX (and the VY I guess)
    Mike
  12. #37
    VS Calais Series II
    Mar 2006
    Pukekohe - New Zealand
    Hello Mike, i'm still debating on buying an ALDL cable for my VS from you. I'm looking at the above diagram, it's different from the www.techedge.com.au one. Could you tell me what models this would work for. Many thanks.
  13. #38
    vp v6 commodore executive
    Aug 2006
    south island newzealand
    Default easy interface 5volt ttl
    just been reading what the honda boys have been doing with a nokia cellphone data cable (come as serial or usb) using it for logging seems to have a max 232 chip in it.looks like the same circuit as some of the max 232 interfaces costs about 25 bucks just cut off the cellphone plug on the end bare the wires and viola .maybe i might of been missing something but have a look schematics for the cable on the net nokia dku 5 or nokia dku 2 or check out www.pgmfi.org let us know what u find out sure beats making one
    heres the schematics they are a bit different but with some modifications might work
    Attached Thumbnails Attached Thumbnails DIY: ECU Scantools/Data Cables-usb-rs232.gif   DIY: ECU Scantools/Data Cables-cable_cell.gif
  14. #39
    michaelw's Avatar
    VX S2
    May 2005
    Newcastle NSW
    Quote Originally Posted by JcB View Post
    It will work for VR/VS/VTS1 V6 and V8, and then VT SII/VX/VY V6's only. (and whatever the matching stateman's and utes are)
    The techedge circuit does not seem to work the VS V8 onwards, I haven't put too much effort in working out where the circuit won't work as the two transistor method seems to work with everything. I use the above circut with obvious modifications for the usb one I sell and have not had any compatibility problems. I originally sold a version based on the tech edge circuit and had troubles.
    But if you are handy with an iron my circuit shouldn't pose any problems.
    Mike
  15. #40
    VS Calais Series II
    Mar 2006
    Default Great! Thanks.
    I'm a learner with the soldering iron, but i like the idea of many models in one circuit. I have not got wiring diagrams from VT or later Holdens, are they the same ALDL connector as the VR/VS? - Thanks for the reply.
  16. #41
    michaelw's Avatar
    VX S2
    May 2005
    Newcastle NSW
    Yep, the same plug and circuit will work for all of the above models.
    Mike
  17. #42
    VY Executive
    Apr 2005
    hey michaelw, do you make and sell these cables at all???? If so how much???
  18. #43
    vt 3.8 series 2
    Feb 2007
    sorry new to this, bought obd2 to db9 diagnostic cable thinking my 1999vt series 2 v6 would be running this protocol. do i need to make/buy an interface to connect to laptop/pda can i use/mod mikes if so. should i use EFIlive4 or winaldl. all help greatlly appreciated thanks.
  19. #44
    michaelw's Avatar
    VX S2
    May 2005
    Newcastle NSW
    Sorry I don't quite follow you. Please ask if I haven't made myself clear.
    1)The VT will not run OBDII it has a OBDII shapped plug but the protocol is different. That said if you have a ALDL cable with a circuit based on an old design your cable will not work.
    2)When you are talking about connceting it to a laptop do you mean you want to run USB?
    3) Can you post a link to what you have bought?
    Mike
  20. #45
    vt 3.8 series 2
    Feb 2007
    sorry mike for not replyin sooner the link if still avaliable is on ebay item # 170084813949 i dont have a laptop yet was thinking of something cheap so serial or usb at this stage prob to suit pentium 3 all help greatly appreciated
  21. #46
    michaelw's Avatar
    VX S2
    May 2005
    Newcastle NSW
    The cable you bought is no good. It is just a bunch of wires with no electronics, also the correct pins for the V6 are not even attached.
    Mike
  22. #47
    vt 3.8 series 2
    Feb 2007
    Quote Originally Posted by Mike:) View Post
    I used EFIlive 4:
    Have fun
    Mike
    Attachment 23463
    Attachment 23464
    Attachment 23465
    Attachment 23466
    Mike cant i make and use this circuit and rewire the plugs to suit or are u saying the obd2 plug is missing the pins to wire up to this circuit and therfore i need to source a new unused obd2 and db9 plug or is this circuit totally unsuitable sorry if this is starting to bother you chris
  23. #48
    VRII Acclaim
    Jul 2005
    You should be able to make it up if you pull your cable apart, all the pins required should be there, but they just wont be connected correctly. But it wont be easy unless you are confident with soldering, have access to a soldering iron, you know what the different electronic parts are, resistors, capacitors etc and how to read what values they are (although there is plenty of help on this on the net if you are willing to learn). You will have to make it up on a prototype board, which can get a bit messy and means you can easily make a mistake just by forgetting to join one wire etc, unless you are willing to make a board up, which is another set of skills again.
    Honestly mate, save yourself the hassle, if you want to connect your car to a computer just get a cable of michaelw. He has put a heap of work into it, it is an excellent product, and it does it for a very reasonable price considering all the work he has gone to.
  24. #49
    michaelw's Avatar
    VX S2
    May 2005
    Newcastle NSW
    Quote Originally Posted by CDS1 View Post
    Use the circuit I posted at the start of this thread. Don't bother with your OBD->DB9 cable, in order to use it you will have to hack through moulded plastic to get to a pin which might not be there. If you want to DIY (and I encourage people giving it a go) I can source you a plug for about $10 that includes postage.
    If there is enough interest I can make you some circuit boards as well.
    Mike
  25. #50
    MY 8.5 Calais V 6.0L, 88 VL Calais Turbo
    Jan 2006
    yeah im interested in a cable! will i be able to re-map the engine/trans ECU in my 2002 VY with this cable and efilive? or it just a diagnostic tool?
+ Reply to Thread
  1. VN V6 vs VN V8 WinALDL data
    By 88GreenVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-03-2009, 01:17 AM
  2. microtech data log
    By krawczuk in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-12-2007, 10:11 PM
  3. Any One Else Have a Data Logger?
    By ViperVp in forum General
    Last Post: 22-01-2007, 12:23 PM
  4. Standard Data set for VN V6
    Last Post: 28-07-2006, 10:06 PM
  5. Factory Scantools
    By GTS1963 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 22-09-2005, 10:22 AM
