2016 vf commodore series 2 lfx v6 3.6 Oil Catch Can
UnstableRage
Launceston Tasmania
VY 2003 V6 3.8 I Series 2
does anyone know where i can get a elite engineering oil catch can for a 2016 vf commodore series 2 lfx v6 3.6?
any info would be appreciated, also if the one mentioned is not correct can someone tell me what is?
also is 212000km ok for a 2016 vf commodore series 2 lfx v6 3.6 if it has full service history history?
stooge
wa
Turbo Alpaca
you dont really need a catch can for it but if you really want one then try contact the company and find out if they have local distributors
if you cant find anything commodore specific the lfx was used in the following vehicles
Year(s)ModelPowerTorqueDyno chart
2012–2016Buick LaCrosse303 hp (226 kW; 307 PS) @ 6800 rpm264 lb⋅ft (358 N⋅m) @ 5300 rpmlink
2013–2015Cadillac ATS321 hp (239 kW; 325 PS) @ 6800 rpm274 lb⋅ft (371 N⋅m) @ 4800 rpmlink
2012–2014Cadillac CTS
(2014 Wagon & Coupe only)
318 hp (237 kW; 322 PS) @ 6800 rpm275 lb⋅ft (373 N⋅m) @ 4900 rpmlink
2014–2015Cadillac CTS
(2014 Sedan only)
321 hp (239 kW; 325 PS) @ 6800 rpm275 lb⋅ft (373 N⋅m) @ 4900 rpmlink
2012–2016Cadillac SRX308 hp (230 kW; 312 PS) @ 6800 rpm265 lb⋅ft (359 N⋅m) @ 2400 rpmlink
2013–2019Cadillac XTS304 hp (227 kW; 308 PS) @ 6800 rpm264 lb⋅ft (358 N⋅m) @ 5200 rpmlink
2012–2015Chevrolet Camaro323 hp (241 kW; 327 PS) @ 6800 rpm278 lb⋅ft (377 N⋅m) @ 4800 rpmlink
2012–2017Chevrolet Caprice PPV301 hp (224 kW; 305 PS) @ 6700 rpm265 lb⋅ft (359 N⋅m) @ 4800 rpmlink
2015–2016Chevrolet Colorado305 hp (227 kW; 309 PS) @ 6800 rpm269 lb⋅ft (365 N⋅m) @ 4000 rpmlink
2015–2016
GMC Canyon
link
2013–2017Chevrolet Equinox301 hp (224 kW; 305 PS) @ 6500 rpm272 lb⋅ft (369 N⋅m) @ 4800 rpmlink
2012–2016Chevrolet Impala302 hp (225 kW; 306 PS) @ 6500 rpm262 lb⋅ft (355 N⋅m) @ 5300 rpm
2014–2020Chevrolet Impala305 hp (227 kW; 309 PS) @ 6500 rpm262 lb⋅ft (355 N⋅m) @ 5300 rpmlink
2013–2017GMC Terrain301 hp (224 kW; 305 PS) @ 6500 rpm272 lb⋅ft (369 N⋅m) @ 4800 rpmlink
2011–2015Holden Caprice281 hp (210 kW; 285 PS) @ 6700 rpm258 lb⋅ft (350 N⋅m) @ 2800 rpm
2011–2013Holden Commodore VE II (MY 2012)281 hp (210 kW; 285 PS) @ 6700 rpm258 lb⋅ft (350 N⋅m) @ 2800 rpm
2013–2017Holden Commodore VF281 hp (210 kW; 285 PS) @ 6700 rpm258 lb⋅ft (350 N⋅m) @ 2800 rpm
F1Aussie
North West Victoria
2011 VE SV6 COMMODORE
That's a bit of a screamer 239kw@6800! What's the difference with that LFX engine vs the VF version?
If you spend some coin on them you can get reasonable gains. Mine has had some massaging and is around 270kw at 6900rpm.
RevNev
VF II SSV Redline Ute
Yes for sure if you massage the engine a bit. I'm wondering what the factory difference is with the Cadillac ATS and the Commodore engine?
stooge
wa
Turbo Alpaca
by the look of it the lfx would on average push out 300hp but i would guess that the version in australia was (de)tuned to be more emissions/fuel conservative.
the version in the ats/cts is probably just tuned more for performance bumping its hp up to 321 from 304~308
they squeeze 335hp out of the lgx while the zb here only got 315hp
NJD-1992
VF-S2 SV6 Commodore
Ive always wondered the same thing regarding the Caprice PPV. Given it came out of the same factory as the VF, and the powertrain from the same engine plant, yet puts out 224KW with similar torque being available down low. Was it a difference in the tune? Different internal bits?
Ive always felt that Holden in part de-tuned the true potential of the VE/VF LFX V6's to make the V8s look more appealing. I mean heck when the L77 was the V8 power plant, if the 6 was knocking out near 240KW like the ATS, doubt as many people would have gone the 8!
dassaur
VF Calais V V8 Wagon
I am sure most buyers wont see it that way but I did not get my l77 based on stock KW figure. The potential is massive as probably the world's most modded (and easiest to mod) engine - everything i've done to it is my own doing (except tune) and I now have 350rwkw
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Probably just dodgy Cadillac figures listed by dodgy General Motors...
RevNev
From a quick read on it, the engines are the same except for the intake manifold on front wheel drive versions and the only variables are intake (airbox), exhaust and tune apparently.
I drove an early VT SS with the 5 litre Holden motor a few weeks ago and I'd be confident to say that a VF SV6 would smoke it. Not long ago, we thought the Holden EFI V8 was pretty fast! A stock L77 with their tall diff ratios were a bit lame I thought.
Similar threads
