Funnily enough, now it won't idle!
Runs great under load, but as soon as you back off, it doesn't like it,
at a constant slow pace it kind of feels like I'm pulling a trailer over bumps, or like ive just started it and driving it cold without a choke but it's certainly not cold!, it's the best way I can describe it.
Every now and then it idles fine,
Hasnt lost any power.
But on the occasion, if I hold the foot flat like it's flooded and start it, it'll be fine...... For a while.
When I stop and pull the choke out, she idles fine,
I've retuned the carby starting from scratch because I thought it may have been that,
Idle mixture, idle reset, float level and re adjust accelerator pump.
There are no vacuum leaks.
It's not the dizzy, just fitted a new hei, had the problem to start with.
Leads are new too.
I feel like it's something to do with the carby.
The next step is changing fuel filter, but it's relatively new.
It started around the same time as it nearly ran dry, and topped it up with fuel siphoned from the commodore.
Bit I can't be sure wether before or after, I don't remember.
But in saying that, the commodore ran like **** too and I haven't sourced that problem either.
I'll ask here first before I start a new thread.
And for memory sake, pre emissions red 253 with 350 Holley.
I'm yet to put the quady on.
One day on the near future.
