Originally Posted by westbad
Got full conversion kit for VN to VS V6
Borg warner T5 gear box, Bell housing, Tail shaft, Floor plate, Center console, Pedal box, Clutch cable, Clutch plate, Pressure plate, Thrust bearing, Fly wheel.
Everything needed to convert a auto to manual.
Will fit VN series 1 all the way up to VS, Can supply it with a 6 bolt flywheel to fit VN series 1 or with the Flywheel and a Castlemaine rod shop conversion plate for $100 extra to make it fit VN series 2, VP, VR or VS. The plate cost $300 from CRS.
$500 for full conversion kit
or $600 with CRS conversion plate to fit VP VR VS
Or alternatively to the conversion plate you can try and find a rare 8 bolt VP-VR-VS flywheel if you want this to fit VP VR VS
Located near seymour VIC
