Air Conditioning Advice
VT&VX
90
VX Acclaim
Is it cheaper to just have a new system installed? or maybe just replace the whole car.
Here are some known problems
#1.. The liquid lines at the reciever drier seize onto to the reciever drier. Replacement of the liquid line from the reciever drier to the tx valve. Or the replacement of the condensor or both. Approx. $190 - $500 gassed
#2.. Discharge hose leaking. Hose from the compressor to the condensor. Approx $200 gassed
#3.. Tx valve leaking. Small valve that regulates the gas flow. Approx. $200
#4.. Evaporator leaking. Behind the dash. (Dash out 10 hours) Approx $850
#5.. Condensor leaks. Normally top left hand side. Approx $500
#6.. Liquid line leaking at P' Clamp on condensor. Approx $190
#7.. Compressor leaking or self distructing. Approx $1200
#8.. Leaking Heater tap. Causes loss of cooling. Approx $60
#9.. Heater tap staying on. Vacuum switch problem. Approx $50
#10.. leaking on floor. Drain tube blocked. Approx. $20 for deblocking
These are the most common problems I get with the A/c system on VR-S Commodores.
Don't be too scared of the problems, just be aware of them and that The A/c does NOT just need "re-gassing" it WILL have a problem.
Regards Guy.
losh1971
North Tas
VE Series I SS Ute
Depends on the issue. I think the issue with mine is the liquid lines if I am correct at assuming that is the correct name for the part?? I had a kinked long hard line the tech showed me a couple of hours ago. To replace and re-gas I am at $260 so far, providing nothing else goes wrong.
losh1971
North Tas
VE Series I SS Ute
My bill has just gone over $400 as I have just found out the condenser is shot.
losh1971
North Tas
VE Series I SS Ute
Aircond advice thread. My advice would be have it checked over thoroughly. Then have the front parts dismantled pipes and condenser taken off and inspect really well for any signs of wear before ordering any parts. Only then decide if you want to proceed, once you start it's hard to know at what point do you stop, because it just becomes ridiculous..??
losh1971
North Tas
VE Series I SS Ute
Ended up costing 610 bucks. And it may still have problems later down the track
Holden chik
41
Waterford Qld
VS SS S2
After running my aircon for about 10min a burning rubber smell starts coming through the vents, started happening earlier this year, any ideas? Had it gassed 5 yrs ago but barely ever use it..
CCCMikey
Black Mountain NSW
VS '95. LPG. 513,000KM
Could be the compressor siezing and causing the belt to get hot as it drags over the compressor? Does it do it on both recycled and fresh air or fresh only?
losh1971
North Tas
VE Series I SS Ute
I'd say the compressor is damaged. They need to be run most of the time to keep them functioning. If you hardly run the aircon the compressor does not get lubricated and eventual fail is inevitable. Although it seems odd that the vents have burning rubber smell because this suggests something is mixing with the air inside the cabin.
losh1971
North Tas
VE Series I SS Ute
Is it burning rubber or burning plastic wire coating? It's somewhat common for the fan motors to fail.
VS_Pete
Donating Member
V6 VS
the aircon is coming on most times and is cold as.
lately start car with aircon on but the cold air don`t work
sometimes the X comes on the screen and other times no X.
everything looks good but no cool air
