Alloytec and You
Discussion in 'VE Holden Commodore (2006 - 2013)' started by mr_s, Jan 19, 2012.
  1. mr_s
    mr_s Member
    VE Lumina 07
    Hi all.
    So, recently I bought a 07 VE Lumina. It's the first commodore I have owned, and love it.
    However, during a brief visit to my mechanic (for brother's car), he took one look at mine and said the Alloytec engines suffer from stretched timing chains.
    Browsing through the forums, I confirmed this is the case for 2006 models; which I guess were the first Alloytec batch.
    Now, how do I determine if my VE has the new revised timing chain, or is one of the first few batches?
    More info:
    87 000 km on speedo
    Manufactured in 08/07
    Engine Number: LEO 072040265
    Searched Google for engine number to no avail.
    Cheers,
    S
  2. Hektic
    Hektic Donating Member
    2006 VE SSV Ignition Orange
    Im prety sure that was with the Vz alloytech but i could be wrong
    Ve alloytech was improved as far as i know
  3. mr_s
    mr_s Member
    VE Lumina 07
  4. TinSnips
    Hills District, Sydney
    VF SSV Ute
    Definitely an issue with 06 VEs. Perhaps give customer no-assistance a buzz with your vin number. May be able to help.
  5. Wongy295
    Wongy295 Donating Member
    2012 VE SV6 (LPG)
    Gday mate.
    I also have a Lumina. Love it alot. :)
    Don't like the front grille though.
    Sent from my Galaxy SII.
  6. The 10th Doctor
    The 10th Doctor ambitious but rubbish
    Perth, WA
    MY12 VE SS-V
    I've got a MY06 VE with the Alloytec - just hit 101,000km and haven't had an issue... yet.
  7. mr_s
    mr_s Member
    VE Lumina 07
    And ask if these cars have had timing chain problems, or what batch the car was?
    Glad to hear it. Lot of people on here have had 06 timing chain problems.
    Don't look at "my ride", I have made a typo (late at night, etc etc)
    So, no members, other than Wongy and myself drive an 07 Lumina here?
  8. carcollector
    carcollector Member
    WM Caprice
    mr_s, looks like you're safe. The service bulletin says;
    "This condition may affect the 7.7 mm pitch timing
    chain, installed in engines after the following engine
    number: H053340001."
    and
    "Improved timing chains were introduced from the
    following breakpoint:
    Engine Number H071380576
    Eng Built Date: 18/05/07"
    and "Typical expectation is that ECM detectable chain elongation
    would occur in early engine life (i.e. 10,000 to 20,000 km)."
  9. flyjoe180
    flyjoe180 Member
    New Zealand
    VE SV6
    That's quite comforting to hear, my 06/07 SV6 hasn't had any timing chain issues and I hope it stays that way.
  10. calais06
    calais06 Donating Member
    Sydney, NSW
    VE Calais MY06
    Mine has 113,000km and no synptoms so far..
    Z3RO a member on here had his chain strech, causing valves to hit the pistons and stuff his engine.
  11. mr_s
    mr_s Member
    VE Lumina 07
    Hey.
    That's great news!
    Where Can I get access to this Bulletin?
  12. greenacc
    greenacc Searching for the billion
    VE Berlina
    The best thing you can do is NOT thrash your car. Keep it below the red line and it should live a long life. Or just replace the chain with a good one when it gets noisy or the warning light comes on, bend over and pay the mechanic, and its all good after that.
  13. mr_s
    mr_s Member
    VE Lumina 07
    Red line.... What the #### is a -
    You mean past 7000 RPM? Good Grief!
    I've never taken a car past 5000, let alone red line. It's like having anal sex without lube... Sure it may feel great for you, but she/he's in a lot of pain
  14. Wongy295
    2012 VE SV6 (LPG)
    I've been up to 5500, only once.
    I was overtaking and was running out of road. Had to keep going to avoid the embarrassment of dropping back. So I slammed it back a gear in Active Select ;)
    Usually I treat my car so tender and lovingly. <3
  15. carcollector
    carcollector Member
    WM Caprice
    Can't find the link at the moment, but here's the text.
    H08-0601-01: Timing Chain Stretch and/or DTCs P0008, P0009, P0016, P0017,
    P0018, P0019
    Built Prior to Engine Number H071380576
    A condition may occur with the HFV6 engine that will cause the MIL
    to illuminate and may log DTCs P0008, P0009, P0016, P0017, P0018 and
    P0019. Codes are set when the ECM detects that camshafts on either
    bank of the engine are misaligned with the crankshaft. For a more
    complete description of code setting parameters, refer to SI.
    Important: This condition may affect the 7.7 mm pitch timing
    number: H053340001.
    The customer will only notice an engine warning light in
    the instrument panel. This condition does not cause any obvious
    driveability concerns or any abnormal engine noises.
    There was an issue with the time chain manufacturing process
    that caused, in a small number of engines, the chain links to
    be outside design specifications. Over time, this may result in
    chain elongation.
    The degree of chain elongation will depend of the number of
    affected links and the drive cycle of the engine during its life.
    If the vehicle meets the criteria explained, with any of
    the previously mentioned DTCs logged in the ECM, the standard
    service instructions for DTCs P0016, P0017, P0018, P0019 and P0008
    and P0009 must be followed, prior to any diagnostic work being done
    on the timing chains.
    Refer to Engine Controls & Fuel – 3.6L,
    DTC P0016, P0016, P0018, P0019 or document # 1985724 in SI or
    Engine Control & Fuel – 3.6L, DTC P0008, P0009 or document #1985715
    in SI.
    ONLY the timing chains need to be replaced.
    Idlers, guides and tensioners do not require replacement.
    However, inspect the guides for any abnormal wear and replace
    ONLY if necessary.
    Once the original used chains have been removed, check the
    free length against new, unused chains to confirm diagnosis. Ensure
    that the chains are either laid flat on a bench and pulled
    straight with no kinks or hung out straight vertically. Typical
    chain elongation observed is a minimum of 3 mm on a doubled-up
    chain, taking an approximate measurement.
    mr_s likes this.
  16. VS_Pete
    I found this site awhile ago don`t know if it will help.
    Holden
  17. RiCeY
    RiCeY F O R U M W A R R I O R
    Australia
    VZ SV8 6spd 5.7
    LOL at being afraid of limiter. The limiter is set to a point that engineers deem a safe level for the engine to rev to. They have to provide warranty for these engines for 3 years so they wouldnt set it to a level that would cause damage.
    Constantly bouncing off it probably wont be healthy but hitting it now and then isnt going to hurt.
  18. adr8
    adr8 Member
    E3 Clubsport R8
    Hitting the rev limiter once a day keeps the mechanic away!
  19. 89vn_Jai
    89vn_Jai New Member
    89 VN Exectutive
    I like this saying :D
  20. mr_s
    mr_s Member
    VE Lumina 07
    Ok, So I realise this is a necro and a half thread, but I just want to take the time and say thank you to all those who replied and gave me comfort.
    Since then she's done 138000 on the speedo (I dont drive much) and still going strong.
    Due for new sparkies tho.
    Thanks mate, I normally keep it below 4k unless I am dragging.
    Hahaha, I am using this one from now on!
    Also, gotta hear that vroom vroom every now and then :)
    Thank you again after all these years collector!
    Legend Kwaka!
    You need to tell me where you get your details from :p
