dav007
- May 12, 2005
- 3
- 0
- 0
- VZ STORM CREWMAN
hi i have a 175 ute and would to change my diff center, what sort of speed are you get in first now. As in first gear i only get about 45 kaysVZSV6 said:no worries. 1/ yes i did it was 22% out, and it was done with a tech 2 but a different version cause of th computer, i got holden to do it, it took them 3 hours for $100. i had gotten a performance place to do it, and he took 1 min but it was still way out. so just go to holden.
2/the rev range has risen by a meezly 200 rpm, doing 100kp/h i'm doing 1900rpm.
3/ all up i paid $1000, new centre new housing. but all in all the best money i have spent on the car by far, the gears are awesome so smooth, you wont regret.
just make sure after 700k's you change the oil. and synthetic all the way.
Sammy said:45km's ... ****, you musn't be pushing it hard then .... my ute does close to 10km's per 1000 rpm, its very very close to 55-60km's in first just before it hits the limiter (6000rpm)
steane said:It's ok. My manual VZ ute has a stuffed fuel gauge and comes up with 10,000 klm service intervals (should be 15,000) so it is no surprise to find that the tacho is out as well!!!
Alloytec said:ok time to set some people straight,
Your fuel gauge has no affect on tacho
Your service interval problem will have no affect on the tacho
Your instrument cluster needs to be reprogramed as a V6 not a V8. wont affect tacho.
As for alloytech redlines / limiters
on the spot 4k limiter
holding in gear 6700limiter (roughly)
in drive rev limiter 6,500rpm
hope that clears some things up.
