Denny pannell
- May 7, 2024
- 4
- 2
- 3
- Age
- 23
- Location
- South Australia
- 2010 ve commodore series 2 llt v6
Hey guys, at a last resort of trying to resolve my issue without spending obsurd amounts of money, I thought I'd come here.
2010 ve series 2 llt, was driving around one day and I had a "service charging system" light come up on my dash. I didn't think anything of it because when I started it again a few times after it'd take a while to come back up, didn't seem like much of an issue. anyway fast forward a few days, this light came up everytime I started it, went for a drive around the block and every light imaginable came up (trac control fault, abs fault, airbag fault, power saving mode, [was also in manual mode and kicked me out of that]) and eventually I was left with absolutely no electronics including speedo and tacho, put itself into limp mode for a little bit, then to top it all off it started running as if it were running on 3 cylinders (foot flat couldn't go above 10km/h)
After messing around with it a while, volts on a multimeter from every electrical point (alt, fuse box, battery) all showed 12.3v with all electronics on or off.
Fast forward some more time, mechanic put a new alternator in, that seemed to fix it, no more alternator light, started and idled fine, until it was revved or driven, then the alternator light comes back up. Mechanic knew how pedantic the VE's can be with their alternators so he put 2 more (genuine I should add) in and same thing, fixed it until it was revved or driven.
Now in engineering mode, it shows up as only 13.3v with everything on or off, and battery percentage only sits at 69.8% but still with alternator light. Have started and stopped it a fair few times now and still starts completely fine.
My question is, has anyone had the same or similar problems that I'm having? How was it resolved? Am I up for a new/remapped ecu/ecm/bcm or is it something else?
I should add all fuses and relays to do with the charging system all are okay.
Cheers everyone
Cheers everyone
