TheForgotten
only human......
- Dec 24, 2005
- 1,372
- 18
- 0
- Location
- quarantine
- Website
- www.holdenscene.com
- VR EXEC
teh order to bleed is furthest from m/c to closest. rear left, rear right, front left, front right. as for how to, I've only done it with an extra person to help. crack bleed nipple, have person 2 pump brakes until all air is gone, hold pedal, tighten screw. repeat for all 4 wheels. may not be the best way but i've had no problems doing it this wayWhat is the correct way to bleed brakes on a VT Commodore, step by step?
Hi Bob - here's a tricky one for you. 98 Vt Senator Hsv.
It wouldn't start tonight. no noises under bonnet, no clicks, no nothing.
check engine light stayed on.
Battery light stayed on, but half as bright as usual,(11.7 volts with mode/up button trick) and the oil light stayed on (need oil pressure to make that go out)
can hear the petrol pump priming.
Had to get it transported home.
Did the pin 5/6 and got no codes out of it as the check engine won't go out.
has code 35 - idle air incorrect, and 92 - low speed fan error, a couple days prior, I'm pretty sure neither of those would stop engine from starting.
Any ideas??
I'm gonna ring the mechanics anyway to come and pick it up again, but would be interested in what you think.
Did you check the crank angle sensor. Apparently they are really common in VT's
Murray
