G'day doc,
I'm new here and may need some advice/help. I just bought a VL Berlina N/A, and was changing the stock stereo over to a CD player. I had the ignition in the ON position to find the power wire when the wife needed help with something urgently and dragged me away from the car. I only discovered I'd left the ignition in the on position about 6-7hours later. The battery was drained and I had to jump start it. Now there are a few problems/questions I have:
1. Should the battery have drained with only the ignition on (no other source of drain that I'm aware of) in that amount of time?
2. Could having the ignition on that long without the car running have damaged my coil or any other of the electrical components?
3. When I jump started it, it coughed and backfired a bit before it got going. As I'd only had the car 2 days, I don't know if this is a new thing or not but it hadn't done it for me prior to leaving the ignition on - had run beautifully.
4. When I got it started, I jumped in and tried to drive to work (6am with headlights on). It ran fine for about 2-3kms and then on the freeway (was doing 100kmph at the time) it just lost all power and spluttered before the battery light came on. I tried starting it again and it was almost flat. Called the MRS and she came and jumped me (about 10 minutes had passed since it died) It spluttered to life again and ran fine all the way home. I then took my other car to work. I thought it may have been battery or alternator related so when I got home, I grabbed the multimeter and checked the outputs at the battery, with the engine at idle, they are as follows:
not running ignition off =12.3v
running nothing on = 14.4v
running everything on = 14.4v
When I started it for this test I didn't need to jump start it but it still coughed and backfired initially. HOWEVER....after it had been idling about 5 minutes, I went to give it a rev and it just started spluttering and misfiring, as I took my foot off the pedal it would smooth out again only to nearly die each time I tried to up the revs.....when it did die, I tried to start it again...only spluttered and coughed, would not catch!.....after 20 minutes I tried again and it started fine though there does apear to be a slight misfire sound when idling.....WTF is going on with it???? If I'd stuffed the coil it would be consistant....wouldn't it?? Any help, suggestions or ideas would be much appreciated......sorry for the long thread...but I know the more info the better.
P.S. Does the VL have codes and if so how do you access them...also, is there a list?
