Auto Transmisson VS s2 7hdd into VS
zed280zx
vs
I have a VS 96 6hdd and I have a VS s2 7hdd to put into it
will this fit and work they both look the same on the Bell housing
smoth casting on will I need to mod some thing as I have a whole
VS2 for parts if needed any help in this area please
PM me or post Thanks
Brett_jjj
Tamworth NSW
vs commodore
If they both have the 13 pin electrical connector, it should all be ok. Some VR 4L60E's (3HDD or 4HDD) only had 12 pins in their connector and these arent compatible with later (VS) models ,as they wont run properly,even though they will physically bolt up.
WAFFEN SS
New Zealand
Charged VS Commodore and 5L VT Clubby
use the vt or vx trans lines and take the computer selector module of the vs box and put it on the new box, thats all I did to fit a VX box in my VS oh and grind a bit of bell housing under the starter motor to fit past the exhaust, I have pacemaker headers so you may have to do more if yours is standed.
Paul13pp
Morayfield Qld
97 VT Exec Wagon
When I changed the engine and auto transmission as a unit last weekend, I had to change the brass auto cooler line adapters that fit to the gearbox. You can use the same cooling pipes tho.
Just swap them over from your old gearbox to the new one prior fitting.
Everything else is the same to fit back up.
The auto that was in my 96 VS is marked 7hdd on the white paper sticker and was really smooth changing gears and selecting drive or reverse even if moving still, somewhat nicer than the one that is in it now.
Might change it back one day.
RX25SE
Real cars are steel cars.
MY07 Liberty 30R Spec B 6sp wagon
As above, just swap over the cooler fitting and thats it.
Apart from larger cooler lines, the 7HDD has an upgraded valvebody and convertor lockup solenoid over the 6HDD, as far as I remember.
