Best VZ workshop manual?
Cracker Wagon
39
SA
VZ
Looking for a good workshop manual to suit a 2006 wagon with alloytec.
I'd prefer a hard copy because it's just easier to use while in the workshop unless there is a significantly better digital version I can print pages from when needed.
Fu Manchu
WA.
There is no better than the Holden manual.
Needs a PC/Mac. Download the folder. Keep the three files in it. Go to start here file. Enable side bar in the pdf reader. Might still require flash player to work as it’s an old document that used it for the hyper links.
https://drive.google.com/drive/folders/1uKn7wFSNkq1OIzVBRGfuQHf6OB8ihmlW
Print what you need. I end up using the computer in the garage now days. Sometimes I’ll print the sections for easy references.
You’re welcome
Cracker Wagon
39
SA
VZ
Thanks for that. I can download the files but not having any joy going to the "start here" and getting an index in the side bar. In the side bar index it just shows the one "start here" page and nothing else
Fu Manchu
WA.
Are you using a computer or an iPad or phone?
As mentioned, you need flash player to work the document.
As mentioned, you need to download the folder, not the files individually.
Fu Manchu
WA.
I have gone on to another mac, gone to the link and it does the same thing because it doesn't have flash player.
Download all three. Put in a folder together.
Lex
Geelong Victoria
VT Executive S1 V6 6 speed Auto Wagon
Flash player is no longer surported.
Fu Manchu
WA.
Fu Manchu
WA.
I’m uploading the folder again. I know this works so will do the link a bit a bit different and see if that helps.
I’ll put the folder in a folder. It should take quite a while for it to download because it’s a few gig.
Lex
Geelong Victoria
It's already in a compressed folder.
BlackVXGTS
Melbourne, SE
.....Might still require flash player to work as it’s an old document that used it for the hyper links.....
Didn't realise that. Never had a problem running it on my Windows PCs, but on checking the apps, I still had Adobe Flash Player installed. You learn something new every day!!
