bled VS but can hear gurgling coming from dash
existentialist
VS
Hey guys
I put in a new radiator into my VS.
I then put the heating on full blast, kept the radiator cap off, and opened the value above the thermostat.
I then filled it until it started coming steadily out of the valve. I lost lots of coolant with the cap off - probably more than I put in, which i guess explains the gurgling.
What am i doing wrong? Is this the right procedure?
88GreenVN
Next Exit Left
60
Surprise, Arizona
Dodge Ram Van 1500 5.2 V8
Cap on, heater on full (not the fan) and then crack the bleed valve.
That's what I'd do.
existentialist
VS
That's what I'd do.
I did it with the cap off. How do i refill it that way? Turn it off, take the cap off and then refill? How long do i have to wait for it with your way?
88GreenVN
Next Exit Left
60
Surprise, Arizona
The process took several days with the VS I had. When cold fill it as much as you can (each time it is cold), then bleed as much as you can out of the top bleed screw after taking it for a drive. I left the cap on so as not to loose coolant.
Immortality
Staff member
Sth Auck, NZ
fill the radiator, run engine with heater on, and bleed valve open. once the engine reaches operating temp the thermostat will open and the radiator level will drop, top up radiator. once coolant starts coming back out of the radiator put the cap on. keep bleed valve open until you get consistent coolant coming out. top up the overflow tank to max. when engine cools the coolant will contract and it will suck coolant from the overflow/expansion tank back into radiator. next time you drive it, bleed it and make sure the overflow tank is topped up. do this a couple of times and it should be fine
88GreenVN
Next Exit Left
60
Surprise, Arizona
That's what I should have said:thumbsup::thumbsup::p
DannyboyDS
Just hand me the pliers.
39
VS Berlina
yeah it always seems to take a few days of topping up and bleeding to get it perfect
