Anyone on here from sydney know where to get a ecu with the part number 92179450, ive tried multiple places but no luck. Ebay doesnt even have the part
How to i check for vacuum leaks? Ive checked many times to see if lines are all connected and they definitely are. Throttle got cleaned a couple days ago, air filters okay, intake looks not to bad. Havnt checked purge valve, its just weird that the code keeps coming up as p0205Throttle is clean? Intake is clean?
Vacuum leaks? Check the PCV hoses.
Is the Purge valve good? Can you blow through it?
Air filter clean?
https://forums.justcommodores.com.au/threads/smoke-test-talks.296764/How to i check for vacuum leaks? Ive checked many times to see if lines are all connected and they definitely are. Throttle got cleaned a couple days ago, air filters okay, intake looks not to bad. Havnt checked purge valve, its just weird that the code keeps coming up as p0205
