just out of curiosity. does it only make it when braking. or when going over bumps aswell?
and is it more of a knock?
if it is it could be a whole range of things (ive got similar problems) and have nearly replaced the entire front end (vs) trying to find it =P
take a look at this and see if it may help
phoenixmechanical vr commodore suspension
Hmph. I'll jack it up later and try to sus it out.Its not brake related.
Sway bar may look fine but the hole could be clapped out.
i looked at a mates vu yesterday about this! no wheel movement and clunking when braking, it turned out to be the arm that comes from the power steering rack, not sure what its called :S lol
The rack end then tierod end. You can feel these rocking the wheel and it doesn't seem to fit the fault described.
As above does it do it over speed bumps too? I'm thinking it could be the sway bar link arms
ball bearings?
do you knwo where they dropepd out of?
(or is that to do with the strut rubber mounts/spinable bearing?)
