Commodore Jack Points
Joelene
VE Commodore
Ever bought a hydraulic jack then found it doesn't come with a rubber bush on the hoist part? So you end up ether destroying the jacking points ie on the VT - VX which is a folded piece of metal or the car slides all over it.
The quick fix for this for VE and VT etc is to buy a $3 rubber mallet from Kmart. Cut the rubber off at the handle and you now have a ready made bush for your jack. You have two actually.
Cut a groove into the one you use for VT-VX and a smaller one for VE.
If necessary file some rubber off the base to make it a tight fit onto the hoist end.
Capsule
Brisbane, QLD
MY09 VE Omega
Clever, I knew about the hockey puck hack but not the Kmart rubber mallet one :)
stockies
Bannana
S/E Suburbs
G6E Turbo
I've never used the factory jack points with a hydraulic jack....
K frame or diff is where i stick the hydraulic jack.
Smitty
Moderator
Bayside Melbourne
GenF SV340 R8 Tourer, VK race car, ZX12R
... I just use the rubber out of an old busted engine mount (I have LOTS of those ;) )
Muke
VE SV6 MY08
The VE has other jack points for hydraulic jacks. The seam is designed for the stock jack only.
uniacidz
Harden the Frak Up
Sideneee
VE Berlina
I just use the chassis
dgp
VF II SSV Redline
Same here..more characters
acarmody
Donati..Whoa Green
VX Berlina
I just use some old thick sock. Use on both by hydraulic jack and chassis stands.
They will only compress so much.
Joelene
VE Commodore
Yep agree with all those comments except never been game to put a hydraulic jack under the diff or under the front stabiliser bar.
Yep use a block of wood etc but once that diff housing cracks or you bend that bar you will soon go back to the jacking points.... :)
But why don't the jack suppliers supply a damn rubber bush!!!
Sabbath'
Redblock Jesus
80 Series// VFII Black Edition
Diff housing crack...lol.
