Dead battery question
VF Calais V
My car hasnt been driven or started in two weeks. I went to unlock my car this morning with the remote and it wouldn't unlock so i used the key, the alarm didn't even sound. I tested the battery with the multimeter only 2 volts!!
The age of the battery is unknown I do have a dashcam that may have been running my question is could the dash cam have caused this in only just 2 weeks or is my battery needing replacement?
shane_3800
35
places
vr commo
Yea dash cam could've caused this. I would replace the battery plates are likely covered in sulfate now and you won't get it all to sluff off.
stooge
wa
Turbo Alpaca
Yep replace it.
Look at getting a power magic pro, it will turn the dashcam off at a certain time or battery voltage preventing total discharge.
VF Calais V
yeah i had a feeling the battery is done for
i have looked at ac delco and i see 3 compatible batteries
600cca
680cca
760cca agm battery
any recommendations?
tml678
2017 HSV30 Senator, 2002 Corolla..
If your're going to park it up for weeks at a time, buy a smart trickle charger like a CTEK MXS 5.0. Once charged, it reaches 'float' mode where it just keeps the battery topped up nicely even If you have parasitic drain like a dashcam.
Smitty
Moderator
Bayside Melbourne
GenF SV340 R8 Tourer, VK race car, ZX12R
600cca
680cca
760cca agm battery
use the factory one again....
I did after my original died earlier this year
(after 5+ years in the car)
gossie
Gold Coast.
VE International 3.6L
Just replace it and if the vehicle is not used a lot purchase a charger at the same time.
You might be interested in considering top of the range by Ernirgi battery as I did.
Anthony121
VF SSV Redline MY17 & VF Director
I
600cca
680cca
760cca agm battery
I just purchased AC Delco S56838 for my Director the other week.
shane_3800
35
places
vr commo
600cca
680cca
760cca agm battery
Use the 680cca one
