Diff oil replacement
SuckSqueezeBangBlow
Heroin White VF2 SS Wagon
hey guys,
I bought 3 bottles of GM#92184900 diff oil from my local dealer as the Castrol website said it would take 2.3L, but the diff only took 1.3L.
Is this normal!??
edit: i have 15k on my car and the fluid was fair grey, with a light metallic (but could just be carbon from the clutches) swirl.
ozNick
VL Berlina 3.0 Auto
1.2/1.3 litres is correct.
SuckSqueezeBangBlow
Thank you
ChRiDDa
N/A
VE SS-Z Sportwagon
Yep, will only get just over a litre in the diff, so 1.2 - 1.3 would be correct
Diff oil stinks and will look quite dirty - I've changed my ve out twice and looks dirty as hell each time
SuckSqueezeBangBlow
I was shocked how little oil it took compared to my old Dmax.
Since the fluid is cheap I will do it every 20k
monstar
Naturally as-pirated
depths of Hays Inlet
facebook.com
Peugeot 207 GTi
With a TruTrac it is even less than a litre, around 900cc.
07GTS
Australia
VEGTS BUILT BLOWN E85
diff oil and the single gearing that does the most work but yet is prob the least serviced, should be done regularly like all oils as oil itself is a wearing part
Banjo79
VF SS Sportwagon
Get mine done annually with transmission oil change, circa 35k. First change old mate said oil was black as, admitted though he doesn't see much diff oil in his line of work and couldn't ultimately comment if it was used or abused. I've never asked about a description since. Adds $10 in labour to my bill.
eman1
newcastle
VF2 Redline
Hey guys,
I know it’s an oldish thread, looking to change the diff oil and deciding between Penrite pro gear 75w85 or the genuine GM oil.
Do you think the genuine stuff is best due to the LSD, however Penrite fluid is suitable for LSD but unsure if it’s best for the diff, it appears both are 75w85 weight oils.
07GTS
Australia
i used the nulon 85-140 in my VE diff and also nulon lsd additive, been handling boost for a few years without any issues
