Does VF2 SSV have an Air Con receiver drier???
Tex308
VF2 SSV Ute, VE V6 Sportwagon
Hi all,
Looking at replacing my leaking aircon hoses on the VF2 SSV Ute and was wondering if the VF has a receiver drier at all?
I am used to the black cannister type and can't seem to find one on my car.
Any help is greatly appreciated.
Cheers.
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Hi all,
Cheers.
I think it's an integral part of the condensor.
Tex308
Thanks. So replacing lines means replacing condenser??
Not a smart design.
Or do people just wing it and not replace receiver drier after leaving the system open to atmosphere??
axemurderer101
Albany
forums.justcommodores.com.au
VY SS
Skylarking
123
Downunder
Commodore Motorsport Edition
Not a smart design.
Yep, most manufacturers integrate the filter/dryer bag in the condenser tank along with a few dye pellets during build process. Seems to be the standard way of doing it these days.
But it is a serviceable item so the whole condenser doesn’t need to be replaced unless it leaks due to impact damage…
With in service vehicles, most ac service places don’t replace the filter/dryer. Admittedly the industry code only requires such to be replaced if the system has been open to atmosphere for more than 5 or 10 minutes. So may be it’s not always needed to change but it’s something I prefer to do every time the system is cracked open whenever a hose is removed.
The annoying part of this modern design is the front bumper should come off to do such filter/dryer changes which may be why many also prefer not to do it (saves on extra labour)…
Parts below
VE S1 (includes new seal, plug and clip) $59
VE S2 & VF (separate links but look identical, no o rings, clips, or plugs, just the bag) $30
(can’t be bothered to search for o rings, plugs or seals which should be replaced to avoid leaks).
lmoengnr
Donating Member
Sunbury Vic.
It's not hard to remove a VE/VF bumper.
Even easier if you hook the bumper on a kerb, then hit reverse (follow me for more driving tips!).:cool:
Tex308
Awesome info! Thank you all.
I'll be doing the labour, so will do it properly.
Cheers!
