After reading the comments, I'd still go alloytec. Yeah there’s a load of parts for the eco and its been track tested and proven buy every man and his dog with great results and a parts list longer then, well its a long list lol... but that’s because its been around for a decade...
The alloy will have the same parts list as the eco in 5-6 years. I remember reading a thing I SC about the LS1, when it first came out everyone was like wtf this eng is going to be **** etc etc, now look at it!
I think this is where the alloytec will head as well, the potential for the eng beats the ecotec hands down. With the way fuel is going V6 are set to become the new V8's, just like what happened in England when fuel prices went bonkers, quick 4's came the best car. AUS will never go that low to have 4's running around but turbo'd and blown six's will be the norm. Some tuner companies are realising this and are tyring to develop the alloy, great move I say.
Conclusion, if you want a car that you can do up straight away, get the gains with proven results after years of testing NOW, buy the eco. If you want something new and uncharted, just like the LS1 was when it came out in the VT's, get the alloy. Great gains to be had out of this engine, its just going to take some time.
Very well said! I agree that it would be a "proven results now!" vs "explore new territory and potentially blow away current results"
of course "exploring new territory" is a MUCH more costly exercise than just buying bolt on parts
, and takes a LOT more time - but the results, and raising the bar for alloytec performance would be well worth it, IMO.
I think the alloytec will prove to be a great motor
From what i remember reading (and pls correct me if i'm wrong)
has
- aluminium block
- 6 bolt (4 down and 2 accross) mains?!
- under piston oil squirties!
From the factory the 190 revs to 6700rpm? (I wonder how much more potential there is there for big rpm? how well balanced is it?)
downside for turbo is the comp is like 10.2:1 - could be getting a little high for boost on crappy pump fuel, but you could always run that E85 fuel that's supposed to be getting approved in Aus in the next few years?
As for tuning..... well really if it's THAT much of an issue, you could just mechanically lock in the variable cam and intake manifold mechanisms, and go with a aftermarket ECU. (although some of these have provision for VCT a'la r32/r33 style - works on the same principle right?, so could probably still utilise them)
Would be great to find out what holden did to their 280kw torana concept TT motor?
The Alloytec engine is used widely around the world, with some models using cool stuff like direct injection! (and saab have a 2.8l turbo version as well, with comp dropped to 9.5:1)
GM High Feature engine - Wikipedia, the free encyclopedia)
IMO, if i had a fair few thousand bucks to play with, and wasn't in a hurry to rip top gear power skids, plus wanted to contribute a bit to the performance development of the Alloytec, i'd be going that way
Otherwise, if I wanted to spend as little money as possible for a proven, tested, safe and reasonably quickly do-able solution, I'd go with the Squeakotec!
