Everything to know about VB - VKs
This thread a good idea?
  • Yes
    Votes: 227 99.1%
  • No (please explain why)
    Votes: 2 0.9%
  • Total voters
    229
RACE5L
Solid cammed
VH 355
I have a vk with a brock Manuel gear box and I also have a vc 1981 sl wagon that's auto, can I do a conversion using the vk gear box in to the vc wagon?
6 or V8? If 6, it will bolt straight up, make sure you use spigot bearing. The floor pan and crossmember are the same VC & VK. Pedal bolt also bolts straight up. Wiring will need a small change. If V8, it will bolt up if a Brock box, M21 or T5G, and the VC has a trimatic.
pushingMACH8
Tamworth
1986 VK Calais
Hey. Are the fuel tanks for sedans and wagons the same?
SquishyShoes
or something like that
Somewhere here...
Shoes
Sorry mate, they're different. Vb-Vs sedan are all same shape but with return line for efi models, and same for ute/wagon tanks for vb-vs.
pushingMACH8
Tamworth
1986 VK Calais
Ah ok cheers. So if I was to use a newer tank from a VS sedan it would fit into the VK sedan?
Heron SSV
Central Coast
They fit but make sure you get the straps with the newer tank. Also, I think the filler necks are slightly different, I think the earlier tanks have the neck as part of the tank and later models they’re separate
gtrboyy
vt ss & lc gtr
Later filler neck trim 25-40mm shorter
Tank straps ends are slightly different from irs cars although really only matters if using bigger 80l off calais/ss etc not the small tanks
Overflow hose is much bigger so may have to tap bootfloor up a bit get hose through chassis rail gap or crush hose.
Other than that get later model plug off donor car for fuel tank sender & pump
Those are basic things
pushingMACH8
Tamworth
1986 VK Calais
Cheers guys.
I'll keep this in mind. Appreciate your replies.
Ronny78
45
Vk Commdore V8
Anyone know the correct spark plugs for a stock standard VK 304?
Smitty
Moderator
Bayside Melbourne
GenF SV340 R8 Tourer, VK race car, ZX12R
original...as back in the day?
or what is now on the market?
Ronny78
45
Vk Commdore V8
Yeh just whats on the market now. I went to a couple of parts stores and got a couple different opinions on what i should use.
