front discs on a vt v6 1999
bones308
vts 1999 V6
hi
do you need a inpact screwdriver to remove the front discs?
edals
You only need a socket set mate. Remove the calliper and bracket. If the disc does not slide off you can use a flat head screw driver in the side vents of the disc to help rock it free.
Kernal
NSW
Dude, theres no such thing as an "inpact screwdriver".
Look in the DIY section its got a how to with pics. Very helpful.
rambunctious
Alexandra Headland Qld
VZ Executive Wagon
He is obviously referring to an IMPACT Screwdriver which is a screwdriver that you hit with a hammer.
Inside the screwdriver is a cam type arrangement which causes force in the direction required in order to remove or tighten a screw. They are used mainly on large phillips screws.
They have been around since before Adam ate the apple.
Like this PROFESSIONAL REVERSIBLE IMPACT SCREWDRIVER DRIVER SET + BIT (Cr-moly) TOLEDO | eBay
bones308
vts 1999 V6
let me rephrase the question
on a Vt V6 1999 is there two phillips head screws which need to be removed attaching the disc to the hub by using a impact screwdriver ?
as the most replacements discs have threads and countersinks for screw heads.
or i'm I looking at the wrong replacement parts (discs)
thank you
SweetWagon
booosted
35
Springwood NSW
VS Berlina Wagon Supercharged
thank you
The disc is only held on by the wheel (and caliper).There is no philips head screws. There is also no "threads and countersinks for screw threads" on the disc's.
Looking at wrong replacement part = yes.
bones308
vts 1999 V6
thank you
i'll do another search on the net for commodore front discs ( i'm only after the standard type)
Sabbath'
Redblock Jesus
80 Series// VFII Black Edition
