front strut question
Snotty
37
the shire!
VR Berlina auto s2
g'day
i recently lowered my car ans when i turn there is a creeking noise from the front springs.
when i got my wheel alignment done the guy said that he thinks the springs are turing and not fixed completly.
any ideas,
do i need to replace the front shocks too?
Bec
VE Calais-V 6L Wagon
Is there any clunking or just creaking/moaning? Could be the strut bearings - either way your shocks should be fine
Snotty
37
the shire!
VR Berlina auto s2
its more of a creaking/moaning noise.
shamden22
shamden22
traralgon
vr executive
mine does the same thing. after i put new springs and struts in i also put new bearings in i thought it was just settling in but its been 6 months now
Snotty
37
the shire!
VR Berlina auto s2
ok, i think i'll give it a while and see how it goes.
drewins
swear word
Gawler S.A.
VS Commodore wagon
its your strut bearings im pretty positive. I lowered mine and had the same problem. Turns out the bearing case in my front left strut was cracked (its plastic). Had to by new bearings and it fixed the problem. Im almost positive. Pull apart your suspension again and pull out the strut bearing and check if it moves freely.
hope that helps
Snotty
37
the shire!
VR Berlina auto s2
cheers, thanks
when i jack the car off the ground the springs are not held firmly and can be rotated by hand. would this be a problem?
markovr
62
northside brisbane
youtu.be
07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
TheForgotten
only human......
quarantine
www.holdenscene.com
VR EXEC
yeah springs turning by hand is bad- allowns bearing plate to move over bumps, cracking bearing case. but I doubt it'll be the bearings, as they make it clunk over bumps.
if it's a moan when turning, try the steering shaft through the firewall. I haven't looked myself, but have been told by a few reliable sources that the shaft isn't covered, and passes through a rubber grommet at the firewall...
