Fuel hose with black clip came out at back of manifold
Trav75
Baldivis WA
vx sedan & vs ute
Hi
Fuel hose pictured came out pictured with yellow tape.
I put back into s bend pipe don’t know if needs some glue or just slides in.
Travis
Trav75
Baldivis WA
vx sedan & vs ute
Hose is out of bootom one of the 3 anyone know why it is different to other fuel hoses
Trav75
Baldivis WA
vx sedan & vs ute
Tank return line?
Hi
I’ve just popped it back in it came out when reconnecting fuel lines.
I’m about to restart up engine concerned this came out.
Any thoughts
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
It's the charcoal canister, vapour purge hose.
It connects to the purge solenoid, then to the T/B.
It's only under a bit of vacuum pressure.
Just push the hard plastic hose into the rubber hose as far as it'll go.
Don't use glue, in case you have to replace the hoses at some stage.
Trav75
Baldivis WA
vx sedan & vs ute
Cheer
Trav75
Baldivis WA
vx sedan & vs ute
Missed where it plugged in underneath TB.
Reconnected hissing noise, rough idling and engine stall all stopped.
Was worried had vacum leak after doing inlet manifold gasket.
NeddyBear
Veteran Mountain Biker
Rubyvale, Qld
2004 2.5L Subaru Outback
Mine popped out about 100 k ago and super glued in back in and no further issues.
Picture - back view of engine with hose.
