Deutscher
Hi guys,
Just tested some more.
Fuel is going through the lines, through the fuel rail and back out the return line.
Hooked Voltmeter to injector connections.. got 12v reading.
So fuel pump is working.
About this fuel regulator? could it be an issue? I don't know how to test it nor get it out.
According to Kopper, it's not my CAS, because I get spark while running on gas and when directly injecting fuel it starts up with ease. About the fuel pressure, I don't know how to test but when we had the hose off it squirted good.
Ok, how do I check if the engine is flooded? also if it is how I fix it?
To moff_man: The case was, car drove fine got home, next morning tried to start car, wouldn't start. Sorry your post is confusing me, I don't know what the DFI, PCM ECM etc does. I'll read some stuff though. Thanks for the hints.
The only thing I want to ask was that, if the float in the fuel tank isn't correctly placed in the fuel tank (it was a mission to get out and in, so maybe it turned or something you know), could this give false information to the engine not to spark the fuel or something? Cause I have no fuel reading on my fuel gauge (there's not much fuel in there... few litres I suppose) but should be enough to start it.
