Skylarking
- Feb 3, 2018
- 10,233
- 10,809
- 113
- Age
- 123
- Location
- Downunder
- Commodore Motorsport Edition
The point I was making is that todays freely available ADR’s are gutted placeholders that reference documents from other jurisdictions (that may not be so openly available)…Yes, it's the same ruling where brake line fittings must be crimped regardless of the hose material. There's additional hose material standards in ADR 42/04 which the braided Teflon hose complies.
The entirety of what brake specific info specified within ADR 42, which supersedes the old ADR 7 is as follows:
ADR 42/00 states
42.13. BRAKE TUBING AND BRAKE HOSE
Air or vacuum brake tubing and air and vacuum brake hose, flexible and hydraulic power hose between the ‘Brake Power Unit 31/00’ or ‘Brake Power Unit 35/00’ and the master cylinder or its equivalent (and thus not subject to ADR 7/... “Hydraulic Brake Hoses”) must conform to BSS, SAE, or other ‘Approved’ standards specified for air brake tubing or hose or vacuum brake tubing or hose or hydraulic power tubing or hose and be so fitted to the vehicle as to prevent chafing, kinking or other mechanical damage under normal motion of the parts to which they are attached.
ADR 42/04 states
15. BRAKE TUBING AND BRAKE HOSE
Flexible hydraulic brake hoses, air or vacuum brake tubing and air and vacuum hose, flexible and hydraulic power hose between the ‘Brake Power Unit 31/00’ or ‘Brake Power Unit 35/00’ and the master cylinder or its equivalent must conform to SAA, SAE, BS, JIS, DIN, ISO or ECE Standards, or FMVSS 106 Brake Hoses, specified for flexible brake hoses, air brake tubing or hose or vacuum brake tubing or hose or hydraulic power tubing or hose and be fitted to the vehicle as to prevent chafing, kinking or other mechanical damage under normal motion of the parts to which they are attached.
Thats it for our ADR’s mentioning stuff about brakes and their construction and nowhere here does it make any mention of crimping or screw fittings…
As I said, I haven’t gone down the rabbit hole but I suspect FMVSS 106 does specify construction methods (as probably others also do).
Whatever the case, you’d expect braided lines with crimp fittings that meet our ADR should still be safe for road use (putting aside the uncertainty of a replacement schedule). However I do take your point that $$ rule and marketing blurbs are full of excrement
