[VIC] Help contact dealer error
BGTURK
Ballarat
Vz SV6
Changed speedometer and got a contact dealership!! Anyone know how to clear this code??
Just Damo
08 Omega, EA Fairmont (Restoration)
Disconnect your battery for half hour and see if that clears it. If not, was it the whole cluster you swapped out?
May need it to be linked with the VIN
BGTURK
Ballarat
Vz SV6
Thanks mate! But unfortunately didn’t work! (Just the cluster)
How do I link to the vin?
Thanks
Just Damo
Thanks
I haven't had it done before, but I believe you will need an auto leccy to match it with a high end scan tool.
Best bet, just call a auto electrician and see what they say. Sorry I couldn't be more help.
Jolls
Donating Member
Murrumbateman
VY SS Ute (Jimi Hendrix)
The cluster will be programmed to the last vehicle so you need a Tech 2 or bi directional scanner with holden codes (Vident/TopDon) to program it to your vehicle. Probably a mismatch between the number of airbags you have and the number programmed. The BCM won't like the mismatch.
Get it so someone who can set it up for you or buy/borrow an appropriate scan tool.
Cheers n Beers
Jolls
Fu Manchu
WA.
Yep, you’ll need the aboves.
LSExtreme will do it via the post.
Envyous Customs here in Perth might still do it.
You’ll also need photo evidence of your current kms. So get the old one in, get the photo with the days news paper (or something like that) in it as well as the kms showing.
They will want to know model, engine, body type (of the car) and how many airbags.
