[VT-VX] How to install a chrome shifter button in your VT/VX
Discussion in 'Holden Commodore How-To's' started by Julie, Sep 21, 2004.
  1. Julie
    Julie moderator- for now anyway
    Western Sydney, NSW
    Blown VT Calais 355 + SC VY V6
    If you want to improve the look of your VT/VX interior on the cheap then this is the perfect mod for you! By simply swapping the plain, bland back plastic shifter and handbrake buttons for the chrome ones found on the VTII and VX calais you will add instant class.
    So I figured since I’m gonna do this anyway why not take some pics and write some instructions while I’m at it so others benefit from my experience. This wasn’t very hard to do and it took less than an hour complete and I’m a girl so u boys should be able to handle this with no probs . You have to agree that the new chrome button looks a hell of a lot better than the dodgy old black plastic one! For such a little cost (about $11 from holden if I remember correctly) it is probably one of the best and cheapest ways to improve your interior.
    So here’s how it is done......
    Step 1.
    First remove the piece surrounding the shifter, to do this you will need to undo the screws on either side of the cigarette lighter (or dummy), now you will be able to lift the surrounding piece high enough to undo the plug for the electric windows (if fitted). You will now be able to remove this surrounding piece.
    Step 2.
    Now you have removed this piece you will see 4 screws underneath where the surrounding piece was, undo these. You will then need to remove the screws joining the suede (or plastic) piece to the console surround. Next open the centre console and under the mat you will see 2 nuts, undo these (they are 10mm). You will find the final 2 screws that you need to remove in the back, put the seats forward and you will see a screw joining 2 plastic pieces. Now you should disconnect the cable for the power window. Now everything is undone you will be able to remove centre console- this is easy just lift it up and move it around a bit until you get it off (it helps if the shifter is in 1st).
    screws
    more....
    more...
    Ozzie, Shounak and Darren like this.
  2. Julie
    Western Sydney, NSW
    Step 3.
    Undo the screw on the back of the gear lever.
    Step 4.
    Look underneath the shifter surround on the passenger side and you will see the shaft for the shifter, if you push the button down you will be able to see the pin. Use a pin pusher or something similar (I used a skinny screwdriver) to remove the pin (this is easy just give it a couple of taps with a hammer).
    Step 5.
    Once the pin is out you will be able to remove the shifter (just a simple case of lifting it up), take the old shifter button out along with the spring. Now put the spring into the new button and place it where the old one was. Now put the shifter back.
    Step 6.
    You will need to hold the button down to replace the pin (it helps to have an extra pair of hands now), lubricate the pin and now put it back in (this can be a bit tricky, I used a hammer and a metal rod)
    Step 7. Reverse the procedure for removing all the plastic bits to reinstall them.
    Step 8. You are now finished, sit back and enjoy looking at a classier interior.
    Step 9. Off to holden to buy the matching chrome handbrake button if you havent already! (don’t worry fitting this is a piece of piss compared to the shift button)
    before:
    and after......
    Well thats it, if you need to know anything else, just pm me. :)
  3. wpr
    wpr New Member
    Auckland, N.Z.
    HSV AVALANCHE WAGON VYII
    Big help
    Hi Julie, thanks to your removal guide for selector surround I was able to install new spring into the small compartment door above the lighter. Schofields Holden in Auckland quoted $120 for labour and parts to fix this tiny spring. I got the part for $23 and saved heaps. Thanks.
    Regards wpr.
  4. Spitfire
    Spitfire New Member
    VT Calais 5.0L
    Do you have the part number for it at all? As the local holden dealer is useless and everytime they order one in its for the wrong model or a completely different thing :| NVM
    Handbrake: 92142530
    Gear: 92141522
  5. jake_au
    jake_au New Member
    WH Statesman 1999
    Anyone know how to fit the Chrome HANDBRAKE button?
  6. VT-565
    VT-565 New Member
    QLD
    VT
    i changed all my door handles and handbrake lever in my vt over to the alloy ones out of the vy ss....one little thing though that i did not realise at the time was the difference in colour of the dash etc....but you would nt notice it unless something was said.....looks the goods....i will post a pic once i have finished painting my dash inserts....
  7. SIXAPPEAL
    SIXAPPEAL Purple Monkey Dishwasher
    HBD Kitted VX on 20's
    After some help thinking someone who might have written in here could help me.
    I've got a VY/VZ Shifter I want to install in my car, I spoke to someone who has put it in their VT, and they said it's not that hard, and they were going to write up a FAQ for it, but never did. I'm aware the shifter's a different size etc.
    He told me that it's pretty basic.. "It's not hard took me about a hour, but that was including figuring out how to do it. It's a matter of braking bits and drilling couple holes from memory"
    Anyone who's taken their dash apart and seen what it's like where the shifter is able to tell me what I'd need to do to get this on?
  8. ScottB_33
    ScottB_33 Go Hard or Go Home
    Nowra
    VTII Berlina Supercharged
    Changing Shift Button to Chrome
    Just carried out your mod for changing the shift button to chrome. Not that hard as you said to do at all. Only pain was getting at the pin with the traction control button in the way but managed it with an extra set of hands. Makes the car look very bling inside. :dance: Thinking about the handbrake one!!
    Great post Julie!!! :bow:
  9. enviousent
    enviousent New Member
    Vt
    been wondering how to change 1 of these, thanx for the info, now ill be able to fit 1 in
    thanx heaps
  10. hinterland
    hinterland commyvt
    vt sed turbo
    hi julie
    great post one question will you marry me.
  11. Julie
    Western Sydney, NSW
    lol sorry hinterland but I believe thats what they call bigamy ;)
  12. vnberlwagon
    vnberlwagon Guest
    I realise VN's have a different type of gear changer, is it possible to put a changer from a later model Commy into an earlier model?
  13. REVDUP
    REVDUP Guest
    any idea where one may buy a chrome button or am i better off just using crome spray paint on my original button....
  14. Shounak
    Shounak The Kicking Horse
    VX Executive S2 + XF Panel Van Project
    Holden.. $25..
  15. wrx884
    wrx884 WA's ASR Rep
    VT Exec/ VT L67 Spac, 5L VP Calais, 77 TC Gemini
    hey just wanna know does ne1 know how 2 take the shifter surround out itself? and do they have pics or detailed info on how 2 take it out? i am trying 2 get 2 the lights inside the shifter surround as im changing the original green colour 2 a diff collour? can ne1 help or show me a thread from somwhere??
  16. slidways
    slidways New Member
    vz acclaim
    Julie u are a god sent this is the second thread that has gotten me out of the poo wif the mrs wot r u doing to that car the other 1 was how to get the door trims off thanks heaps julie keep the good work coming
  17. Miss-E
    Miss-E VTCOM6
    VT Commodore
    I'd like to know how to change the colour of the lights for drive-1st too if anyone has any ideas?
  18. SLAF
    SLAF New Member
    Outer North Eastern Suburbs Melb
    VE SSV UTE
    I had to replace a split handbrake knob on my Calais. It's only plastic though. Pull the cover up, remove it and the knob just unscrews. I had a silver ring around the end of the lever which was also split but I didn't bother replacing that. It just clips on too. Cost about $10.00
  19. roby02
    roby02 New Member
    fairview park SA
    VT Equipe wagon
    was just about to do a new thread asking about how to remove the centre console but thanks JULIE you have saved the day :thumbsup::thumbsup:
  20. Phreddy
    Phreddy Bye SV6 - still love you
    W-Sydney NSW
    VS-II Statey-8
    Great post Julie - THANX!!
