how to remove radio/heat/ac facia panel
glenn l
ve sv6
as the title says, how do you remove the facia panel on a ve sv6?, i have a little rattle behind it.
RiCeY
F O R U M W A R R I O R
Australia
VZ SV8 6spd 6.0 430rwhp
Its just clipped in, pull it towards you from the bottom where you can get your fingers behind it.
You have to pull fairly hard be carefull not to hit the gear lever.
glenn l
ve sv6
thanks RiCeY, do you pull the metal bit as well or just the plastic facia?
RiCeY
Australia
The whole lot, the facia has a metal backing plate. Should be about 3/4" thick.
Natecamo
Kambalda
VE SS ute
Good info posted... Though I've pulled the side panels off the side of head unit, how do I tell which wires are the speaker wires??
MYVESSV8
Brisbane/GoldCoast
VE 6LT M6
by the colours (hahaha),
  • ve speakers.doc
