M
matt69
Guest
bolt on a supercharger. is that large scale enough?
patullose said:Are they Hard to Install?
AirStrike said:get some 3.45 diff gears from a VL from the wreakers
HDT_aero said:did you manually shift if not do so it will hold a little longer but practise before you race again so you get it perfect
take all the weight possible out of your car ..... including passengers spare wheel and jacks etc anything that doesnt need to be in there take out.
make sure your car is warm aswell this will help a little
a cold air intake will help (cheap way out is to wack a pod on the end of the pipe just before the airbox and get rid of the airbox..
get som1 in your car and get the to put the acellerator all the way to the floor and make sure that thebuttefly in the throttle opens as far as it can... if not then tighten the cable accordingly.
and if you take of the throttle body and the elbow piece theres a bellmouth (like a little plastic cup) take this out for better air flow...
thats about it for little to no cost mods you could do to get you the advantage.
statesman_vs_s1 said:What year MR2?
A mk1 or a mk2.
Mk1 has a 100kw 1.6litre 4AGE motor (4AGZE if imported)
Mk2 has a 3S-GE which is a 2litre twincam 16valve throwing out a healthy 127kw......
My mum has a Mk2 with 104,000 genuine kms on the clock.
I have a 1996 VS Statesman, my sister has a 01' Holden Astra,
and my mate has a 1983 Dick Johnson Grandprix LE XE falcon 4.1 turbo
(one of 24 made)....
and the mr2 beats them all...
Let us know how you go second time around.
