I snapped a Plenum Chamber bolt on the VS
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by James39, Jul 16, 2011.
  1. James39
    James39 Gave up on VL's
    Newcastle NSW
    1995 VS Acclaim & 1992 Holden Barina
    Stupid me snapped a bolt on the Plenum Chamber :(
    So I am checking to find out if if I can replace the broken bolt or would I need a new Plenum Chamber?
  2. seq4x4
    seq4x4 New Member
    Sunshine Coast, Queensland
    VS
    Which bolt mate? Inside or the lid? Iv got all my spares from when i put my spacer and insulator in. To be honest, they look like a standard bolt.
  3. cander24
    cander24 New Member
    NSW South Coast
    VZ GTO. VS LS1.
    More importantly, where is the rest of the bolt? Still in the inlet manifold? Can you remove it?
    No you don't need a new plenum. Whilst the plenum bolts are relieved in the centre and supposed to remain as part of the plenum, they can be removed by un-threading them out of their hole or vise versa for fitting a replacement.
  4. HarmlessMuffinMan
    HarmlessMuffinMan New Member
    Armidale, NSW
    VX Commodore 2002 Executive v6. Ex Patrol Car
  5. James39
    Newcastle NSW
    Good to know.. thanks for that info.
    Yeah the rest of the bolt is still in the inlet manifold :( Not sure how much thread is in it though... My torque wrench failed so i will have a look again when i get a new one hopefully this Sunday... I am sure it will not be hard to remove?
    So I can only get this bolt from a Holden dealer?
  6. seq4x4
    seq4x4 New Member
    VS
    Do you have a easy out kit? Used for getting snapped bolts out. Or even a reverse thread bolt/screw?
  7. seq4x4
    seq4x4 New Member
    VS
    Just dug through my bucket of VS bolts. Im going to guess its a seat bolt, its an allen key head, roughly the same length. Pack it up with some washers. That will do untill you get another bolt. See attached. Well you cant since i just killed my phone again :(
  8. James39
    Newcastle NSW
    I would have to get one.
    Looking down the hole on the plenum you could see where it has snapped off... Hopefully there will be enough there for me to use vise grips or something when I take the plenum off....
  9. James39
    Newcastle NSW
    Thanks for that info :)
  10. seq4x4
    seq4x4 New Member
    VS
    Iv sent you a PM. Also i dont know if it was a seat bolt. I forgot some VK stuff got chucked in there. But not many other allen key bolts are in the commos that i can remember.
  11. James39
    Newcastle NSW
    I have replied, thanks for all your help :)
  12. James39
    Newcastle NSW
    I just torqued the remaining 4 bolts to 20 mn, do you think this should be ok?
  13. seq4x4
    seq4x4 New Member
    VS
    Iv never torqued my plenum bolts. But the plenum barly stays on it atm cause its on and off.
    Iv never had a leak before.
    Should bolt one of these on :p :
    Just about, roughly 5mm, from the casting marks in the manifold is where the plenum meets manifold.
  14. BlackVXGTS
    BlackVXGTS Well-Known Member
    Melbourne, SE
    VF2 GTS A6, VS Calais 383 A4, VS Clubsport 185 A4
    Service manual says 10-14Nm.
  15. James39
    Newcastle NSW
    Yeah I knew about that, but I did it higher to compensate for the snapped bolt lol
  16. James39
    Newcastle NSW
    Does it help with performance?
    Mine needs a clean, but it is not that bad considering the amount of K's it has done...
  17. James39
    Newcastle NSW
    All fixed today so I am happy :)
