Used that a couple of times in the past from Melville United (Perth).yea must have some additives in it maby extra toluene which can be bad for paint but helps out the MON real good, we use to have the P100 here that was united 98 with 10% ethanol blend
Great experiment. I'll definitely be following for results.Following some discussion in my Mini thread, I am doing a little experiment to establish if JB Weld is indeed fuel resistant and if ethanol has any increased negative effects over 91.
I have coated some rebar in JB Weld, allowed it to cure for some 28 hours and immersed them in jars of 91 and E85.
I have put the jars in the garage so they shouldn't be impacted by UV.
Will check them in one week for any changes.
nice idea.... but will tell you the results, nowFollowing some discussion in my Mini thread, I am doing a little experiment to establish if JB Weld is indeed fuel resistant and if ethanol has any increased negative effects over 91.
Guess that’s the difference when they say something is fuel “resistant” as compared to something which can be fuel “immersed”…Pull the carb apart and the JB WELD was just not there, it had basically melted
Project Farm does some great comparison videos on lots of stuff.View attachment 249049
“How will JB Weld hold up to E85? Let’s get the testing underway.”
That's like Araldite versus 5-minute Araldite, the quick stuff turns to bubblegum after a couple of weeks.As an aside, original jb weld is far more chemical resistant compared to the quick version.
No, it’s in the same toothpaste style. In the dirt bike world, it’s well known that you can’t use the quick version to fit magneto magnets in where the magneto’s immersed in oil. Some have found that out the hard way!Is the "quick version" the plunger tube style ?
