Clacker
- Mar 17, 2005
- 230
- 0
- 0
- Age
- 45
- Location
- Perth
- VS Exec Series II
hako said:If your dipstick indicates the oil level is correct when the oil is hot then don't worry. If it is slightly over then that should not be a problem unless your are way over. If you are really worried then loosen an oil cooler hose connection and let some drain out (with engine switched off). If you think it is 200ml over then that is bugger all. The dipstick lock was installed on the VS when the Ecotec motor came out - the 4L60E transmission would overheat when towing and a service bulletin was issued. The VS11 also had an external oil cooler added as an extra precaution. I've never seen a clip on the filter - it is held in place by the oil sump when it is bolted up - the rubber seal on the filter neck is to prevent the oil pump sucking air which leads to sloppy changes (if at all). It is virtually impossible to stuff something up by changing the oil/filter/gasket so don't blame yourself unless you happened to somehow get the rubber seal out of position - you did remove the old one? - and the new filter had the seal on the neck?. Sound like you did everything correctly.
The "clunk" is probably not related to the trans oil change and purely coincidental. Good Luck.
Thanks Hako,
I left the rubber seal that was in there as I read that its a bitch to get out and its fine to keep old one there. I took the seal off the new filter.I looked up the hole and nothing looked out of alignment. The new filter installed ok and was a snug fit so I assume that means the seal was in correctly.
Thanks
Clacks
