Keeping Engine Warm??
VS_Pete
Donating Member
To me I would think the TPS would have a flat surface to bolt on to like the iac.
Maybe make a gasket for it.
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
It does mount to a flat surface. May be the photo's a bit misleading.
It's just that gap underneath that worries me.
That machined out, horse shoe shape mates up with the TPS.
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
Yeah....The sealed bearing is recessed on the shaft.
I was talking about the horse shoe shape on the mating surface.
Anyway....I am just trying to eliminate all possibilities.
VS_Pete
Donating Member
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
Tried a gasket as you suggested, to try and block off that gap under the TPS.
No go I'm afraid.
It spaces the TPS out too far and the shaft can't connect to the TPS properly.
Mind you' I did use cork (that I had lying around) which I thought would be too thick.
Might try paper gasket material, as it's much thinner.
Although I don't think it'll work.
Immortality
Staff member
Sth Auck, NZ
Here are some pictures.
I don't have a Factory T/B to compare it with unfortunately.
The first picture has the measurements of the connection to the TPS.
And this one for good measure.
Right, I'm with you now.
Yeah, that shaft doesn't look like it need the plastic sleeve as it seems a lot bigger than the standard TB shaft. I'll measure up a standard shaft later.
Dayvo
Because i can
67
South East,Victoria
VE SV6 Series 2
Try one of these , I found it in an old copy of Practical Motorist dated October 1960
NeddyBear
Veteran Mountain Biker
Rubyvale, Qld
2004 2.5L Subaru Outback
Our baby always runs better in the cold.
