Loose steering column - help!
Scatman696
47
Currans Hill NSW
Vk berlina
Can't say I had that issue with the 3 columns I have done....The last one was about 10 years back.....
The bracket at the base of the column isn't catching on a pedal or alikes, not allowing the column to move downwards?
Something to look at
No I don’t believe it’s catching. I don’t want to tap the stem down or I’ll most likely collapse it.
We are close but no cigar yet!!
Scatman696
47
Currans Hill NSW
Vk berlina
I have been told by a wrecker that you leave the bottom bracket last and force it on with a screw driver.
Haven’t tried that yet.
I had thought of taking the column out and tapping it backwards - but most likely to break the pins I guess?
I’m sort of stuck hard. Just having a refresh / break from it for my sanity
vc commodore
Like the Leyland Brothers
VC, VH and VY
Yes, the bolt at the base of the column should go in, once you have at least 1 nut on the studs.....Not before....
Honestly, I have never struck the issue you describe when I have replaced he column.....
I've slid the intermediate shaft onto the rack, and the column lines up with the studs that come out of the dash..
Scatman696
47
Currans Hill NSW
Vk berlina
So basically attempt to get one of the dash bolts in and then engage the bottom base with bolt and it should be good?
Scatman696
47
Currans Hill NSW
Vk berlina
If I jack the car up and turn the wheels will this help me get a better angle? more room? I have loosened the bottom bolt and am able just to get both of the dash bolts on, however the third under dash bolts does not line up at all no matter what I do. I was thinking if I was to jack the car up and turn the steering slightly will this help? I'm stuck and out of ideas.
vc commodore
VC, VH and VY
Has the alloy slotted tab in the column moved? From memory they can move in the column slots
Scatman696
47
Currans Hill NSW
Vk berlina
Yes I noticed that it does it pulls downwards a little but when I try and seat it up on the bolts and into the bottom bracket under pressure it feels jammed. I don’t want to go two hard and sheer the pins.
