[LS1] LS1 roller rockers
cracker
theres no way in hell your going too see 254 rwkw with basic mods and rockers.
Darcon666
Evil is always around you
At home
www.gfy.com
Your Mother
^^^^^^ Agreed... Stock LS1 and the only thing changed is rockers & tune, not a chance.
Now if it's an LS2/3 and has had a re-tune/FULL Exhaust, springs & pushrods .... 220/30 even 245(freak Engine...) and the rockers - and it's a MAYBE from me(I could be wrong and the Dyno is a "Happy" one...) :D
Immortality
Staff member
Sth Auck, NZ
MACE sell re manufactured stock rockers. 1.9 ratio (standard 1.7) check there website
Vt_vic
perth,Western Australia
carless for now
ive seen quite a few tune and exhaust ls1's making 340rwhp its a very high number and overinflated but there are a few around
cracker
exhaust tune, intake and a mafless, should expect 220-240rwkw anything more is just bull ****
2DIE
ONEDOLLAHOLLA
South Aus
www.torn.com
97 Acclaim
Back on topic, it wont be massive gains but they will have gains. If you plan to get a cam down the track I wouldn't worry about high ratio rockers.
HIGH RATIO ROLLER ROCKERS TO SUIT VT-VZ LS1-LS2 V8'S - Mace Engineering Group
For $475 its one of the cheaper options for more power, I don't know about the V8s but for the V6 its the 2nd best thing next to a cam at quarter of the price.
MACE
We haven't tested 1.8:1 rockers, we've done 1.9:1, 2.0:1 and 2.1:1
The latter two require the cylinder heads to be modified around the pushrod area.
Gains we got on a mainline dyno were 11, 13 and 8rwkw respectively.
These tests were done on a bolt on NA VT LS1. Hopefully sometime this year we should have results on a L76 engine so that should be interesting :)
Depending on the ratio, rockers as a bolt on item definitely work. Not as well as a larger cam, but then again everyone's requirements and budgets are different.
Cheers,
Steve
ejukated
VS Calais L67
Ive personally tuned 2 ls1's with rockers, full exhaust, OTR and mafless. The manual one made around 253rwkw and the auto one less (cant remeber the exact number). I know that if you have the mafless tune spot on then add rockers you run pretty lean up top which indicates the VE increases by a decent amount with rockers. I wouldnt reccomend running rockers on a regular mafless tune unless your mixtures are pretty fat to start with.
Be good if anyone else has dynosheets from 1.8s and a tune to suit to compare.
Darcon666
At home
www.gfy.com
Your Mother
Managed to dig a little and found that the vehicle used originally had 241.9rwkw(So DEFINITELY NOT a STOCK LS1 from all accounts...) then 1.8 installed which took it up to 253.4rwkw... so only an increase of 11.5rwkw.
Sooo.... I stand by what I said.... STOCK/FACTORY LS1 + 1.8/1.9 Roller Rockers and a MAF tune does not = 253rwkw
Towcar
Auckland NZ
VX Berlina Wagon
Thead dig I know... but
I have my car in being tuned and having an OTR CAI installed.
Want to work with the tuner on a plan to upgrade. I don't want to go the cam route as I need to tow a horse float with my horse in it, and a lumpy cam wont work for that.
I was thinking of changing to higher ration rockets and uprated valve springs to get a gain, not as much as a cam obviously but a small increase while keeping the standard drivability.
Who has actually fitted higher ration rockers on a stock cam?
Don't care so much about the top end power as I only ever see my car around 5,800rpm anyway looking at achieving a fatter torque curve thru the range.
