I just randomly bumped into this thread/site after looking up LS1-related ****.. thought I'd help out.
I done this conversion about 5 years ago. LS1/T56 into my VH. I put the eng/trans in myself, bought a conversion kit off Castlemaine (mounts, starter adapter plate, mini starter, rip shifter, headers...) got Electronic Auto. to take care of the wiring for me, got the McDonald Bros to weld up the corners of my sump after I chopped 'em for k-frame clearance, Prof.Exhaust to modify the extractors as they wouldn't fit, got my tailshaft shortened, slapped VT brakes on...
I ended up crashing the damn thing (thanks to old unroadworthy tyres + a crappy wet road) which makes me :censored: :bomb: Ran like a dream but.. just like I knew it would.
Anyways, looks like you got the clutch sorted.. as for the ECU, mine's mounted under my dash (pas. side). Fits perfectly - above and away from feet.
I left that solenoid on the trans you were talking about and just bashed out my tunnel to make room for it.
I don't remember having probs with my coil touching my brake booster..
Sorted out your accel.cable yet (assuming ur going the cable-route)? Think I used a VR one.. which was a bit too long and had to loop it around where it hooks up above the pedal. Shave off some of that accel.cable/linkage-stop thing on your T/B btw, to allow your flap to fully open (as it doesn't from factory) for more power.
I too had an engineer (Bill Malkoutsis or someshit) come over my place to check it out mid-build.. what a joke. Mfer charged me $264 to pretty much just tell me:
- Have a fingers tip worth of clearance all around your engine/sump/exhaust.
- Run your wiring on the opposite side of your fuel line(s).
- Run those late model clip-on fuel fittings (which Elec.Auto. told me to f-em-off as they are **** and just use normal clamps).
- You need to run the same pollution crap of the car that engine came from.
Yeh that's pretty much it. The rest of the time he was telling me about what parts of U.S. he'd been to. I should've kicked him off my driveway and told him to f-off when he charged me that.
Oh yeah.. VL tank, Bosch external pump (not a damn 044 which everyone buys for some unknown reason), fuel press.reg mounted under the car near my tank, pollution canister also mounted near the tank, spun my fuel rail around to make the outlet/inlet closer to the line... ah memories :bang:
How much did you pay for the shorten tail shaft and where abouts.
