When I got my VS, it was a bit shaky at idle and seemed to vibrate a fair bit when driving along. I had already serviced all the usual parts, oil and oil filter, air filter, petrol filter, auto trans filter, new plugs and leads, etc etc, but it was still not 100% right. I then replaced the engine mounts, the universal joints and centre bearing, I also replaced all the rear suspension bushes. After these were all done, it completely fixed the vibration I was getting whilst driving along. It still idled a bit rough, so then I changed the coils and DFI module, and cleaned the throttle body and plenum, this got rid if the shaky idle. Also I found that after I had fitted brand new injectors, I noticed that the engine was idling and running even smoother still. Id be looking at all these parts and making sure they are all 100% before replacing timing chains etc.
Ive found that when replacing ignition coils or engine sensors etc, its best to use genuine holden parts if you can, even though genuine parts are more expensive, they will usually last longer and will run a lot better than most of the el cheapo ones. The ignition coils seem to slowly loose their "edge" over time until they get to a point where they completely fail. I have tested the fuel economy difference between old and new coils, and new coils definitely give better fuel economy,(and run way better) even thought the old coils still ran good..
Remaunfactured/reconditioned injectors dont seem to make much of a difference to fuel economy or running etc,(unless your old injectors are completely knackered). Brand new injectors are the way to go. Its the same with injectors as it is with ignition coils, they slowly loose their "edge" over time. And once injectors are 3 or 4 years old, they should be replaced if you want to get the best performance and economy from your car. When I changed my injectors, I found brand new ones on ebay for around $160, so I thought Id try them,as they wanted $150 in town here to recondition my old ones,so I bought these cheap ones, and so far theyve been excellent. I usually wont buy el cheapo parts, but holden wanted $120 each for brand new bosch injectors for my VSV6, so I thought Id give these cheapies a go at least, and see how they go, because at $160, well, its not a great deal if they turn out to be no good.. But anyway, they have been excellent so far, the car starts instantly now, it runs a lot better and smoother and gets excellent fuel economy. Ive finally got it to where im happy with how it drives,runs etc.
