Hey mate, not sure on the GTS rims, but in my opinion the current ones you have on it look amazing.
I if were you I'd just lower the car a tad and then leave it as is.
Any of you guys on here with Stato's had to modify your guards to fit 19's??
Quick question. If I was to put the VX GTS rims on, would I need to roll the rear guards to fit them under?? It sits reasonably low at the rear at the moment, not sure if it's been lowered, these didn't come with fe2 or anything, so not sure if it's just the stock height.
I did the tyre/rim comparison online, and it worked out that the overall diametre was actually going to be a 10mm smaller, so in theory, they should fit no drama's ay??? Or is there more to it than that?
I had them on the BT1, and they fit fine, no scraping etc, and that had the stock fe2. But the BT1 had arched guards, whereas the Caprice is straight.
