Its different with IRS you need to take the shock of to do it properly and best use spring compressors so you dont have a spring under tention fling out and smack you in the leg while your jumping on a jack handle. If you go to a place like BURSONS use to be motor traders you get the parts pretty cheap, my springs cost me
$115 for the rear King springs any size
$99 for the front king springs
Front struts were $106 each
Rear where $103 for the pair
Ended up costing me $530 i did it all myself so thats all it cost and ill align it myself at work as im an aligner.
You may not get it that cheap but normally if you go via a mechanic or pedders they put at least 15/20 % markup on everything plus fitting, so your best just buying parts and getting them to fit them. Also id also make sure when its lowered it gets aligned by someone who adjusts camber not just some clown who toes cars up and thats it.
If someone that knows what there doing does it you dont have to worry about it falling apart on you its all done properly and at once, and normally you can get an alignment cheaper when you get the person to fit them. Check your swaybar links as well while its apart if there not to crash hot might be worth while changing.
I was looking at this kit on ebay.
$620 posted is pretty good, prob another $120/$150 to have it fitted and aligned as well
eBay Australia: Buy new & used fashion, electronics & home d
