itsme4g63
- Jul 12, 2013
- 22
- 0
- 0
- Location
- Chicago, IL
- 2004 Pontiac GTO
Hey guys, new member here, I own a 2004 GTO, been a long time fan, my friend had his since it was brand new and I knew I had to have one ever since. Its a 6 speed, wouldn't have it any other way, and has 57xxx miles. Drive it on the weekend mostly and just get her washed up/waxed/shammied/microfiber cloth dried and she stays sitting pretty in the garage. Enough of my ramblings:
here are the mods:
Fuel-
-Walboro 255 in tank
-#42 green top injectors
Motor-
-Svede OTR cold air intake
-Fast acting upgraded IAT sensor
-SLP MAF
-ported stock Tb had to get a new blade water jetted for it,
-ported intake
-243 heads tons of port work and welded chambers equates to 12.5:1 compression.
-TSP 228r camshaft on a 112 lsa
-TSP double roller timing chain
-Kooks longtubes 1-3/4" to SLP LM1 catback, originally catted mids but cut open and hollowed out
-DBA slotted rotors with NEW pads front and back
-B&M short throw shifter
-Skip shift eliminator
-Wideband on Apillar
-ARP head studs
-LS7 clutch/ PP/ and Flywheel
-Drag bags in rear springs with valve mounted in the trunk.
Appearance-
-OEM SAP grilles painted semi gloss black
-JHP lip spoiler for australia (where the car originates from the monaro) also painted semi gloss black
-trunk lid was welded and painted to cover the stock spoiler holes
-HIDs lows and fogs white low beams, yellow fogs
-DEPO tail lights from JHP
-fog relay cancel, normally when you turn the high beams on, the fogs turn off. I disabled it so the fogs stay on. It throws a ton of light on the road.
video of it running:
Aside from the mods in my list I installed Cadillac CTS-V 4 piston front brembos, which I designed the bracket kit for to work with a brembo friendly 32mm rotor. Same brembos as as in the VE redline/Camaro SS/Pontiac G8 GXP (I also designed 6 piston front/4 piston rear kits to work with vx/vy.vz.vt chassis). I was hellbent on getting it done to fit with these absurdly concave stock gto 17's, am unsure if you guys get these there as well. Stopping power has been greatly improved. Background pic is in front of the Field Museum here in Chicago.
I don't think the brake fluid has ever been changed prior to my install! It was super brown/dark! Word of advice if your car has over 50k on it change your brake fluid if you haven't done so already!
[/QUOTE]
Dyno day dyno
Being as this is on a mustang dyno and not dynojet, which reads 10-15% higher, I think I am on par with my mods, (somewhere in the 430-440whp dynojet region)
-Damian
here are the mods:
Fuel-
Motor-
-SLP MAF
-ported intake
-ARP head studs
Appearance-
Dyno day dyno
-Damian
